查看: 2009|回复: 0
关于fpga警告的问题
lkwendy 发表于 2011-7-28 15:30:33 | 显示全部楼层 |阅读模式
Warning: Creation of Node or Bus "a[0]" failed. Duplicated nodes are not inserted. Node or bus name "a[0]" already exists.
Warning: Creation of Node or Bus "a[1]" failed. Duplicated nodes are not inserted. Node or bus name "a[1]" already exists.
Warning: Creation of Node or Bus "a[2]" failed. Duplicated nodes are not inserted. Node or bus name "a[2]" already exists.
Warning: Creation of Node or Bus "a[3]" failed. Duplicated nodes are not inserted. Node or bus name "a[3]" already exists.
Warning: Creation of Node or Bus "a[4]" failed. Duplicated nodes are not inserted. Node or bus name "a[4]" already exists.
Warning: Creation of Node or Bus "a[5]" failed. Duplicated nodes are not inserted. Node or bus name "a[5]" already exists.
Warning: Creation of Node or Bus "a[6]" failed. Duplicated nodes are not inserted. Node or bus name "a[6]" already exists.
Warning: Creation of Node or Bus "a[7]" failed. Duplicated nodes are not inserted. Node or bus name "a[7]" already exists.
Warning: Creation of Node or Bus "b[0]" failed. Duplicated nodes are not inserted. Node or bus name "b[0]" already exists.
Warning: Creation of Node or Bus "b[1]" failed. Duplicated nodes are not inserted. Node or bus name "b[1]" already exists.
Warning: Creation of Node or Bus "b[2]" failed. Duplicated nodes are not inserted. Node or bus name "b[2]" already exists.
Warning: Creation of Node or Bus "b[3]" failed. Duplicated nodes are not inserted. Node or bus name "b[3]" already exists.
Warning: Creation of Node or Bus "b[4]" failed. Duplicated nodes are not inserted. Node or bus name "b[4]" already exists.
Warning: Creation of Node or Bus "b[5]" failed. Duplicated nodes are not inserted. Node or bus name "b[5]" already exists.
Warning: Creation of Node or Bus "b[6]" failed. Duplicated nodes are not inserted. Node or bus name "b[6]" already exists.
Warning: Creation of Node or Bus "b[7]" failed. Duplicated nodes are not inserted. Node or bus name "b[7]" already exists.
俺初来咋到,懂得太少,有哪位好心人帮我看一下,这些警告信息是什么意思。。。多谢。。。
GMT+8, 2026-5-23 22:05 , Processed in 0.031148 second(s), 19 queries .
