查看: 1795|回复: 3
PS2实例代码
fpga_feixiang 发表于 2020-8-4 17:00:51 | 显示全部楼层 |阅读模式
简单实例代码如下:
#include<REG52.h>
sbit LS138A=P2^2;
sbit LS138B=P2^3;
sbit LS138C=P2^4;
sbit BEEP = P1^5;
sbit Key_Data = P1^6 ;   //定义键盘引脚
sbit Key_CLK = P3^2;     //使用外部中断
void Decode(unsigned char ScanCode);  //解码子程序
void delay(unsigned int i);      //函数声名
void display();
void beep();
// 此表为 LED 的字模            // 0    1    2    3    4    5    6   7    8    9    A    b    c    d    E    -    L   P    U   Hidden  _ (20)
unsigned char code Disp_Tab[] = { ~0xC0,~0xF9,~0xA4,~0xB0,~0x99,~0x92,~0x82,~0xF8,~0x80,~0x90,~0x88,~0x83,~0xC6,~0xA1,~0x86,~0xbf,~0xc7,~0x8c,~0xc1, ~0xff,  ~0xf7 };
bit BF;
unsigned char KeyV;
unsigned char LedNumVal  ;
int KEY_val,IntNum;
void main()
IT1 = 0;                              //设外部中断1为低电平触发
EA = 1;                               //外部中断开
EX0 = 1;                              //开中断
  while(1)
   if (BF)
if (KeyV != 240)  beep();
       Decode(KeyV); //解码
      EA = 1; //开中断
   display();
void Keyboard_out(void) interrupt 0
if ((IntNum > 0) && (IntNum < 9))
KeyV = KeyV >> 1;                //因键盘数据是低>>高,结合上一句所以右移一位
if (Key_Data)
     KeyV = KeyV | 0x80;          //当键盘数据线为1时到最高位
IntNum++;
while (!Key_CLK);                //等待PS/2CLK拉高
if (IntNum > 10)
   IntNum = 0;                  //当中断11次后表示一帧数据收完,清变量准备下一次接收
   BF = 1;                      //标识有字符输入完了
  EA = 0;                      //关中断等显示完后再开中断
void Decode(unsigned char ScanCode) //注意:如SHIFT+G为12H 34H F0H 34H F0H 12H,也就是说shift的通码+G的通码+shift的断码+G的断码
   switch (ScanCode)
   case 0x70 :             // 当收到0xF0,Key_UP置1表示断码开始
    KEY_val = 0;
    break;
   case 0x69 :
    KEY_val = 1;
    break;
   case 0x72 :
    KEY_val = 2;
    break;
   case 0x7A :
       KEY_val = 3;
    break;
   case 0x6B :
    KEY_val = 4;
    break;
   case 0x73 :
    KEY_val = 5;
    break;
   case 0x74 :
    KEY_val = 6;
    break;
   case 0x6c :
    KEY_val = 7;
    break;
   case 0x75 :
    KEY_val = 8;
    break;
   case 0x7d :
    KEY_val = 9;
    break;
     case 0x71 :
   // dot = 0X7F;
    break;
BF = 0; //标识字符处理完了
zhangyukun 发表于 2020-8-4 18:04:03 | 显示全部楼层
PS2实例代码
zxopenhl 发表于 2020-8-7 17:13:11 | 显示全部楼层
PS2实例代码
GMT+8, 2026-5-22 19:38 , Processed in 0.032983 second(s), 23 queries .
