查看: 3069|回复: 1
FPGA的速度等级(speed grade)
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-5 21:06:58 | 显示全部楼层 |阅读模式
XILINX公司FPGASpartan 3E系列XC3S500E速度等级为4.但一直不知道是什么意思.
通过学习知道,
(1)CPLD与FPGA的速度等级定义的区别
(2)不同的公司FPGA的速度等级
(3)同一个公司的不同时期的定义也是不一样的,如XLINX公司
具体内容可以参考以下材料.也可以在GOOGLE里输入FPGA SPEED GRADE
(4)对于xilinx公司的FPGA的速度等级定义,个人观点:它不是以前所定义的其内部的一些逻辑单元信号传播所花的时间,而是一类内部逻辑器件的运行速度,这些逻辑器件运行时满足一定要求的时钟频率.它没有具体的物理的数据意义,只是一类内部逻辑器件的运行速度的的代号.
There is no consistent definition of aspeedgradefor all devices. Even forXilinx,
speedgrades mean different things depending on if you are referring to a FPGA or a CPLD. For CPLDs,speedgrades represent the time it takes for logic to go through the device (eg. in <= out). So a -10 device means that the device is guaranteed to send a signal from an input pin thru to an output pin in under 10 nS. So for CPLDs, the lower the number, the faster the part is. This is standard for CPLDs across all vendors so this can be used for device comparison purposes.
what is the valve of standard grade(FPGA)
However for FPGAs, they don't use the same definition forspeedgrade. Originallyspeedgrades for FPGAs represented the time through a look up table but now thespeedgradedoesn't actually repesent a timing path. I am not sure if it is the same for other vendors, but forXilinxFPGAs higher numbers are faster. Eachspeedgradeincrement is ~15% faster than the one before it. So a -5 is 10% faster than a -4speedgrade.
Determining the speed grade of Xilinx devices
Q:
I am having some trouble understanding the numbering system Xilinx uses for speed grade. Could someone explain what the numbers are and how to tell which speed grade is installed on my XS40. FWIW I have an XC4010XL FPGA. The available speed grade choices are -1, -2 -3, or -09.
A:
You usually see the speed grade imprinted on the chip on a line by itself. For an XC4000, you might see "3C" printed on the chip. That means the chip has speed grade -3. (I think the "C" stands for commercial temperature range.)
For XC4000 devices, the number is roughly equivalent to the propagation delay through a CLB. So a -3 speed grade implies 3 ns of delay through a level of logic, -2 means 2 ns. Don't be mislead by -09, it actually means 0.9 ns of delay.
The situation changes with Spartan and Virtex devices. Now a larger number means the device is faster.
Reference :http://www.xess.com/faq/M0000236.HTM
Question:
Date Posted : 12/11/2004 4:42:49 AMHi guys,
What is the speed grade in FPGA. What it tells actually.
Thanks in advance,
Soundar
Comments:
Posted : 12/27/2004 12:54:29 AMHi
It is actually the min I/O delay for that device.
Ex: for altera MAX device EPM7128... -15
this -15 indicates this device has min of 15 ns. i/o delay.
yogesh
ASIC
FPGA
VHDL
VERILOG
CMOS
SEMICONDUCTORS
MICROPROCESSOR
PLACE AND ROUTE
MIXED SIGNAL
MISCELLANEOUS
POST A QUESTION
SIGN UP
LOGIN
CHANGE PASSWORD
speedgrade
Category:FPGA
Question:
Date Posted : 7/19/2006 5:19:41 AM While usingxilinxsynthesis tool, in the synthesis reports I found a term calledspeedgrade: -6, what does this actually mean??
Comments:
Posted : 7/20/2006 12:53:49 AM Hi,
Use this field to test aspeedgradewith your design. Changing thespeedgradehelps determine a need to target a faster device to meet your timing requirements, or if using a slowerspeedgradestill meets timing constraints. Select aspeedgradefrom the pull-down list, which contains the availablespeedgrades for the target device.
Changing thespeedgradein the Options tab tests it with the design; it does not change thespeedgradein your FPGA design file.
regards
muthukumar.p
Posted : 7/27/2006 6:06:01 AM THE FREQUENCY OF DESIGN DEPENDS UPON SELECTED DEVICESPEEDGRADE.
suppose u have design that is working on 50 mhz,with a device whosespeedgradeis 6.
now if u want to work at 70 Mhz frequency.and withspeedgrade6 u r not acheving that much frequency with that device.then if u take same device with morespeedgradethen this its sure that ur design fequncy will also increase but it is more costly then then the earlier.
if still have any doubt ask dont hesitate
v.lakhanpal@coraltele.com
vikas lakhanpal
engineer
vlsi designs
coral telecom
Posted : 7/27/2006 6:07:11 AM i think that is the importance ofspeedgrade.
Posted : 7/27/2006 6:07:13 AM i think that is the importance ofspeedgrade.
Posted : 7/28/2006 2:20:34 AM Thanks for ur comments Muthu Kumar and Vikas.
In my search I have found my answer, n thought of sharing...
Internal frequency is thespeedat which CPLDs/FPGAs can perform. operations or transfer data internally. The propagation delay is the time interval between the application of an input signal and the occurrence of the corresponding output in a logic circuit.Speedgradeindicates the delay in nanoseconds (ns) through a macrocell in the device. For example, a device with aspeedgradeof –10 has a delay of 10 ns through a macrocell. Devices with lowspeedgradenumbers run faster than devices with high-speedgradenumbers.
speedgradeof -09 implies a delay of 0.9ns.
Posted : 7/30/2006 11:23:51 PM Hi surekha,Where u get these ideas?provide the source. i have doubt about your answers.myself and vikas going into the same direction i.e when the devicespeedgradeis increase then thespeedof the device also increase.but your answer is different.I warm welcome to all the readers.pls share your points about this question.
regards
muthukumar.p
Posted : 7/31/2006 2:12:06 AM Hello,
I have seen the details at the following links.
http://cpld.globalspec.com/
http://www.altera.com/products/devices/dev-format.html
http://cpld.globalspec.com/Learn ... _Logic_Devices/CPLD
I hope the definition ofspeedgradefor FPGA and CPLD are the same. I think the minus indicates the samething, i.e., as the delay increases thespeed(frequency) reduces.
Posted : 7/31/2006 11:44:50 PM Hi thanks ,to day i got the new idea from u.
xilinxfpga point of view -7speedgradedevice faster than -6speedgradedevice.
But altera cpld point of view -10speedgradedevice slower than -9speedgradedevice.
ok
-10 and -9 are denotes the macrocell propagation delay.
but if u know any specification of -7 or -6 in FPGA.Anybody knows pls let me know.
regards
muthukumar.p
Posted : 8/2/2006 4:58:03 AM Hi Muthu,
I can give you some more clearification about FPGAspeedgrades.
In an FPGA the fabricator devides the devices in to some categories.Speedgrade-7 means that there is a range of macrocell delay in FPGA which is kept in this category.
But in cplds -10 means the macrocell delay is 10 ns.
Hope the same is helpfull.
rgds
Posted : 9/2/2006 5:15:56 PM surekha n all comment after checking this site
Posted : 11/9/2006 1:14:49 AM hi guys,
I just read ur comments.
If I have been told to describleSpeedgradein a sentence,I would say " Its a minimum i/o delay".
This means a signal will take atleast this much of time to travel from i/p to o/p.
Posted : 11/9/2006 1:21:26 AM hi,
You usually see thespeedgradeimprinted on the chip on a line by itself. For an XC4000, you might see "3C" printed on the chip. That means the chip hasspeedgrade-3. (I think the "C" stands for commercial temperature range.)
For XC4000 devices, the number is roughly equivalent to the propagation delay through a CLB. So a -3speedgradeimplies 3 ns of delay through a level of logic, -2 means 2 ns. Don't be mislead by -09, it actually means 0.9 ns of delay.
Sunlife 发表于 2015-4-7 11:34:40 | 显示全部楼层
GMT+8, 2026-5-23 12:13 , Processed in 0.031177 second(s), 21 queries .
