查看: 1561|回复: 7
RS纠错编码和解码
fpga_feixiang 发表于 2020-12-30 14:12:21 | 显示全部楼层 |阅读模式
//rs code
//m=8
#include <math.h>
#include <stdio.h>
#include <string.h>
#define mm  8          /* RS code over GF(2**4) - change to suit */
#define nn  255          /* nn=2**mm -1   length of codeword */
#define tt  10           /* number of errors that can be corrected */
#define kk  235           /* kk = nn-2*tt  */
int pp[mm+1] = {1, 0, 1, 1, 1, 0, 0, 0, 1};
int alpha_to [nn+1], index_of [nn+1], gg [nn-kk+1] ;
int recd [nn], data [kk], bb [nn-kk] ;
void generate_gf()
/* 生成GF(2^m)空间 */
        register int i, mask ;
        mask = 1 ;
        alpha_to[mm] = 0 ;
        for (i=0; i<mm; i++)
                alpha_to[i] = mask ;
                index_of[alpha_to[i]] = i ;
                if (pp[i]!=0)
                        alpha_to[mm] ^= mask ;
                mask <<= 1 ;
        index_of[alpha_to[mm]] = mm ;
        mask >>= 1 ;
        for (i=mm+1; i<nn; i++)
                if (alpha_to[i-1] >= mask)
                        alpha_to[i] = alpha_to[mm] ^ ((alpha_to[i-1]^mask)<<1) ;
                        alpha_to[i] = alpha_to[i-1]<<1 ;
        index_of[0] = -1 ;
        //alpha_to[nn] = 1;
        for(i=0;i<mm;i++)
                printf("gf%d is%d\n",i,alpha_to[i]);
void gen_poly()
/* 生成---生成多项式*/
        register int i,j ;
        gg[0] = 2 ;    /* primitive element alpha = 2  for GF(2**mm)  */
        gg[1] = 1 ;    /* g(x) = (X+alpha) initially */
        for (i=2; i<=nn-kk; i++)
                gg[i] = 1 ;
                for (j=i-1; j>0; j--)
                        if (gg[j] != 0)
                                gg[j] = gg[j-1]^ alpha_to[(index_of[gg[j]]+i)%nn];
                                gg[j] = gg[j-1] ;
                gg[0] = alpha_to[(index_of[gg[0]]+i)%nn] ;     /* gg[0] can never be zero */
   //printf("polynomial:\n");
   //for(i=0; i<=nn-kk; i++)
        //   printf("%d      ", gg[i]);
   //printf("\n");
   /* convert gg[] to index form for quicker encoding */
   for (i=0; i<=nn-kk; i++)
           gg[i] = index_of[gg[i]];
   //printf("\n");
void encode_rs()
/* 编码*/
        register int i,j ;
        int feedback ;
        for (i=0; i<nn-kk; i++)   bb[i] = 0 ;
        for (i=kk-1; i>=0; i--)
                //逐步的将下一步要减的,存入bb(i)
                feedback = index_of[data[i]^bb[nn-kk-1]] ;
                if(feedback != -1)
                        for (j=nn-kk-1; j>0; j--)
            if (gg[j] != -1)
                                bb[j] = bb[j-1]^alpha_to[(gg[j]+feedback)%nn] ;                //plus = ^
                                bb[j] = bb[j-1] ;
                        bb[0] = alpha_to[(gg[0]+feedback)%nn] ;
                                bb[j] = bb[j-1] ;
                        bb[0] = 0 ;
void decode_rs()
{/*解码*/
        register int i,j,u,q ;
        int elp[nn-kk+2][nn-kk], d[nn-kk+2], l[nn-kk+2], u_lu[nn-kk+2], s[nn-kk+1] ;
        int count=0, syn_error=0, root[tt], loc[tt], z[tt+1], err[nn], reg[tt+1] ;
/* first form the syndromes */
        for(i=0; i<nn; i++) //转换成GF空间的alpha幂次
                if(recd[i] == -1)
                        recd[i] = 0;
                        recd[i] = index_of[recd[i]];
        for (i=1; i<=nn-kk; i++)
                s[i] = 0 ;
                for (j=0; j<nn; j++)
        if (recd[j]!=-1)
                        s[i] ^= alpha_to[(recd[j]+i*j)%nn] ;      /* recd[j] in index form */
        /* convert syndrome from polynomial form to index form  */
                if (s[i]!=0)
                        syn_error=1 ;        /* set flag if non-zero syndrome => error */
                printf("%3d", s[i]);
                s[i] = index_of[s[i]] ;
        if (syn_error)       /* if errors, try and correct */
    {printf("*\n");
/* compute the error location polynomial via the Berlekamp iterative algorithm,
   following the terminology of Lin and Costello :   d[u] is the 'mu'th
   discrepancy, where u='mu'+1 and 'mu' (the Greek letter!) is the step number
   ranging from -1 to 2*tt (see L&C),  l[u] is the
   degree of the elp at that step, and u_l[u] is the difference between the
   step number and the degree of the elp.*/
/* initialise table entries */
                d[0] = 0 ;           /* index form */
                d[1] = s[1] ;        /* index form */
                elp[0][0] = 0 ;      /* index form */
                elp[1][0] = 1 ;      /* polynomial form */
                for (i=1; i<nn-kk; i++)
                        elp[0][i] = -1 ;   /* index form */
                        elp[1][i] = 0 ;   /* polynomial form */
                l[0] = 0 ;
                l[1] = 0 ;
                u_lu[0] = -1 ;
                u_lu[1] = 0 ;
                u = 0 ;
                do
                        u++ ;
                        if (d[u]==-1)
                                l[u+1] = l[u] ;
                                for (i=0; i<=l[u]; i++)
                                        elp[u+1][i] = elp[u][i] ;
                                        elp[u][i] = index_of[elp[u][i]] ;
/* search for words with greatest u_lu[q] for which d[q]!=0 */
                                q = u-1 ;
                                while ((d[q]==-1) && (q>0))
                                        q-- ;
/* have found first non-zero d[q]  */
                                if (q>0)
                                        j=q ;
                                do
                                        j-- ;
                                        if ((d[j]!=-1) && (u_lu[q]<u_lu[j]))
                                        q = j ;
                                }while (j>0) ;
/* have now found q such that d[u]!=0 and u_lu[q] is maximum */
/* store degree of new elp polynomial */
            if (l[u]>l[q]+u-q)
                                l[u+1] = l[u] ;
                                l[u+1] = l[q]+u-q ;
/* form new elp(x) */
                                elp[u+1][i] = 0 ;
            for (i=0; i<=l[q]; i++)
                                if (elp[q][i]!=-1)
                                        elp[u+1][i+u-q] = alpha_to[(d[u]+nn-d[q]+elp[q][i])%nn] ;
                                  elp[u+1][i] ^= elp[u][i] ;
                elp[u][i] = index_of[elp[u][i]] ;  /*convert old elp value to index*/
                u_lu[u+1] = u-l[u+1] ;
/* form (u+1)th discrepancy */
        if (u<nn-kk)    /* no discrepancy computed on last iteration */
                        if (s[u+1]!=-1)
                                d[u+1] = alpha_to[s[u+1]] ;
                                d[u+1] = 0 ;
            for (i=1; i<=l[u+1]; i++)
                                if ((s[u+1-i]!=-1) && (elp[u+1][i]!=0))
                                        d[u+1] ^= alpha_to[(s[u+1-i]+index_of[elp[u+1][i]])%nn] ;
            d[u+1] = index_of[d[u+1]] ;    /* put d[u+1] into index form */
        } while ((u<nn-kk) && (l[u+1]<=tt)) ;
        u++ ;
        if (l[u]<=tt)         /* can correct error */
/* put elp into index form */
/* find roots of the error location polynomial */
                /*求错误位置多项式的根*/
                for (i=1; i<=l[u]; i++)
                        reg[i] = elp[u][i] ;
                count = 0 ;
                for (i=1; i<=nn; i++)
                        q = 1 ;
                        for (j=1; j<=l[u]; j++)
                        if (reg[j]!=-1)
                                reg[j] = (reg[j]+j)%nn ;
                                q ^= alpha_to[reg[j]] ;
                        if (!q)        /* store root and error location number indices */
                                root[count] = i;
                                loc[count] = nn-i ;
                                count++ ;
                                printf("根%d=%d\n", q, nn-i);
                if (count==l[u])    /* no. roots = degree of elp hence <= tt errors */
                {/* form polynomial z(x) */
                        for (i=1; i<=l[u]; i++)        /* Z[0] = 1 always - do not need */
                                if ((s[i]!=-1) && (elp[u][i]!=-1))
                                        z[i] = alpha_to[s[i]] ^ alpha_to[elp[u][i]] ;
                                else if ((s[i]!=-1) && (elp[u][i]==-1))
                                        z[i] = alpha_to[s[i]] ;
                                else if ((s[i]==-1) && (elp[u][i]!=-1))
                                        z[i] = alpha_to[elp[u][i]] ;
                                        z[i] = 0 ;
                                for (j=1; j<i; j++)
                                        if ((s[j]!=-1) && (elp[u][i-j]!=-1))
                                                z[i] ^= alpha_to[(elp[u][i-j] + s[j])%nn] ;
                                z[i] = index_of[z[i]] ;         /* put into index form */
  /* evaluate errors at locations given by error location numbers loc[i] */
                        /*计算错误图样*/
                        for (i=0; i<nn; i++)
                                err[i] = 0 ;
                                if (recd[i]!=-1)        /* convert recd[] to polynomial form */
                                        recd[i] = alpha_to[recd[i]] ;
                                        recd[i] = 0 ;
                        for (i=0; i<l[u]; i++)    /* compute numerator of error term first */
                                err[loc[i]] = 1;       /* accounts for z[0] */
                                        if (z[j]!=-1)
                                                err[loc[i]] ^= alpha_to[(z[j]+j*root[i])%nn] ;
                                if (err[loc[i]]!=0)
                                        err[loc[i]] = index_of[err[loc[i]]] ;
                                        q = 0 ;     /* form denominator of error term */
                                        for (j=0; j<l[u]; j++)
                                        if (j!=i)
                                                q += index_of[1^alpha_to[(loc[j]+root[i])%nn]] ;
                                        q = q % nn ;
                                        err[loc[i]] = alpha_to[(err[loc[i]]-q+nn)%nn] ;
                                        recd[loc[i]] ^= err[loc[i]] ;  /*recd[i] must be in polynomial form */
                else    /* no. roots != degree of elp => >tt errors and cannot solve */
                {        /*错误太多,无法更正*/
                        for (i=0; i<nn; i++)        /* could return error flag if desired */
                                if (recd[i]!=-1)        /* convert recd[] to polynomial form*/
                                        recd[i] = 0 ;     /* just output received codeword as is */
                else         /* elp has degree has degree >tt hence cannot solve */
                {        /*错误太多,无法更正*/
        else       /* no non-zero syndromes => no errors: output received codeword */
                                recd[i] = 0 ;
                        //printf("*");
int main()
        int i, length;
        char strSrc[255], strDst[255];
        printf("请输入要编码的字符串:\n");
        scanf("%s", strSrc);
        length = strlen(strSrc);
        if(length <= 0)
                return 0;
        generate_gf();
        printf("Look-up tables for GF(2**%2d)\n",mm) ;
        printf("  i   alpha_to[i]  index_of[i]\n") ;
        for (i=0; i<=nn; i++)
                printf("%3d      %3d          %3d\n",i,alpha_to[i],index_of[i]);
        printf("\n\n");
        gen_poly();
        for(i=0; i<kk; i++)
                data[i] = 0;
        /* for example, say we transmit the following message (nothing special!) */
        for(i=0; i<length; i++)
                data[i] = strSrc[i];
/*        data[0] = 8 ;
        data[1] = 6 ;
        data[2] = 8 ;
        data[3] = 1 ;
        data[4] = 2 ;
        data[5] = 4 ;
        data[6] = 15 ;
        data[7] = 9 ;
        data[8] = 55 ;*/
        encode_rs();
        data[0] = 19 ;
                recd[i] = bb[i] ;
        for (i=0; i<kk; i++)
                recd[i+nn-kk] = data[i] ;
/*        printf("Results for Reed-Solomon code (n=%3d, k=%3d, t= %3d)\n\n",nn,kk,tt) ;
        printf("  i  data[i]   recd[i](decoded)   (data, recd in polynomial form)\n");
                printf("%3d    %3d      %3d\n",i, bb[i], recd[i]) ;
        for (i=nn-kk; i<=nn; i++)
                printf("%3d    %3d      %3d\n",i, data[i-nn+kk], recd[i]) ;*/
        decode_rs() ;
                strDst[i] = recd[i+nn-kk];
        strDst[length] = '\0';
        printf("%s\n", strDst);
zhangyukun 发表于 2020-12-31 09:22:55 | 显示全部楼层
RS纠错编码和解码
大鹏 发表于 2021-1-4 09:43:39 | 显示全部楼层
RS纠错编码和解码
zxopenljx 发表于 2025-5-28 09:40:25 | 显示全部楼层
RS纠错编码和解码
GMT+8, 2026-5-22 08:05 , Processed in 0.032642 second(s), 23 queries .
