查看: 1883|回复: 3
异步FIFO 的Verilog实现
fpga_feixiang 发表于 2021-1-23 15:28:06 | 显示全部楼层 |阅读模式
module  fifo
  parameter WSIZE = 8;
  parameter DSIZE = 32;
  input wr_clk,
  input rst,
  input wr_en,
  input [WSIZE-1 : 0]din,
  input rd_clk,
  input rd_en,
  output [WSIZE-1 : 0]dout,
  output reg rempty,
  output reg wfull
//定义变量
reg [WSIZE-1 :0] mem [DSIZE-1 : 0];
reg [WSIZE-1 : 0] waddr,raddr;
reg [WSIZE : 0] wbin,rbin,wbin_next,rbin_next;
reg [WSIZE : 0] wgray_next,rgray_next;
reg [WSIZE : 0] wp,rp;
reg [WSIZE : 0] wr1_rp,wr2_rp,rd1_wp,rd2_wp;
wire rempty_val,wfull_val;
//输出数据
assign dout = mem[raddr];
//输入数据
always@(posedge wr_clk)
  if(wr_en && !wfull)
    mem[waddr] <= din;
//1.产生存储实体的读地址raddr; 2.将普通二进制转化为格雷码,并赋给读指针rp
always@(posedge rd_clk or negedge rst_n)
  if(!rst_n)
    {rbin,rp} <= 0;
    {rbin,rp} <= {rbin_next,rgray_next};
assign raddr = rbin[WSIZE-1 : 0];
assign rbin_next = rbin + (rd_en & ~rempty);
assign rgray_next = rbin_next ^ (rbin_next >> 1);
//1.产生存储实体的写地址waddr; 2.将普通二进制转化为格雷码,并赋给写指针wp
always@(posedge wr_clk or negedge rst_n)
  if(!rst_n)
    {wbin,wp} <= 0;
    {wbin,wp} <= {wbin_next,wgray_next};
assign waddr = wbin[WSIZE-1 : 0];
assign wbin_next = wbin + (wr_en & ~wfull);
assign wgray_next = wbin_next ^ (wbin_next >> 1);
//将读指针rp同步到写时钟域
  if(!rst_n)
    {wr2_rp,wr1_rp} <= 0;
    {wr2_rp,wr1_rp} <= {wr1_rp,rp};
//将写指针wp同步到读时钟域
  if(!rst_n)
    {rd2_wp,rd1_wp} <= 0;
    {rd2_wp,rd1_wp} <= {rd1_wp,wp};
//产生读空信号rempty
assign rempty_val = (rd2_wp == rgray_next);
  if(rst_n)
    rempty <= 1'b1;
    rempty <= rempty_val;
//产生写满信号wfull
assign wfull_val = ((~(wr2_rp[WSIZE : WSIZE-1]),wr2_rp[WSIZE-2 : 0]) == wgray_next);
  if(!rst_n)
    wfull <= 1'b0;
    wfull <= wfull_val;
zxopenhl 发表于 2021-1-23 16:19:20 | 显示全部楼层
异步FIFO 的Verilog实现
zhangyukun 发表于 2021-1-23 17:34:14 | 显示全部楼层
异步FIFO 的Verilog实现
508482294 发表于 2021-12-10 17:02:35 | 显示全部楼层
异步FIFO 的Verilog实现
GMT+8, 2026-5-22 14:27 , Processed in 0.053771 second(s), 19 queries .
