查看: 1789|回复: 3
sdram读程序实例
fpga_feixiang 发表于 2021-3-18 14:22:03 | 显示全部楼层 |阅读模式
`include "camera_head.v"
module read (pi_clk, pi_rst_n, po_read_bus, pio_sdram_dq, pi_sdram_addr, po_sdram_rdata, po_rdfifo_wrreq,
                        po_read_done);
        //        system
        input                                pi_clk;
        input                                pi_rst_n;
        //        sdram
        output        [17:0]                po_read_bus;
        inout        [15:0]                pio_sdram_dq;
        // in data
        input        [11:0]                pi_sdram_addr;
        //out data
        output        [15:0]                po_sdram_rdata;
        output                                po_rdfifo_wrreq;
        output                                po_read_done;
        reg                                flag;
        reg                [15:0]        dq_buf;
        assign         pio_sdram_dq = flag ? dq_buf : 16'hzz;
        reg         [3:0]        commands;
        reg                [1:0]        sdram_bank;
        reg                [11:0]        sdram_addr;
        assign        po_read_bus[17:14] = commands;
        assign         po_read_bus[13:12]        = sdram_bank;
        assign        po_read_bus[11:0]         = sdram_addr;
        reg                [15:0]                po_sdram_rdata;
        reg                                        po_rdfifo_wrreq;
        reg                                        po_read_done;
        reg                [3:0]              state;
        reg                [8:0]                cnt;
        always @ (posedge pi_clk, negedge pi_rst_n)
                        if (!pi_rst_n)
                                        commands <= `NOP;
                                        sdram_bank <= 2'b00;
                                        sdram_addr <= 12'd0;
                                        flag <= 1'b0;
                                        dq_buf <= 16'd0;
                                        po_sdram_rdata <= 8'd0;
                                        po_rdfifo_wrreq <= 1'b0;
                                        po_read_done <= 1'b0;
                                        state <= 0;
                                        cnt <= 9'd0;
                                        case (state)
                                                0 :        begin
        commands <= `ACT;
        sdram_bank <= 2'b11;
        sdram_addr <= pi_sdram_addr;
        state <= 1;
        flag <= 1'b0;
                                                1 :        begin
        if (cnt < 1)
        commands <= `NOP;
        cnt <= cnt + 1'b1;
        commands <= `RD;
        sdram_addr[10] <= 1'd1;
        sdram_addr[8:0] <= 8'd0;
        cnt <= 9'd0;
        state <= 2;
                                                2 :        begin
        if (cnt < 2)
        commands <= `NOP;
        cnt <= cnt + 1'b1;
        po_sdram_rdata <= pio_sdram_dq;
        po_rdfifo_wrreq <= 1'b1;
        cnt <= 9'd0;
        state <= 3;
                                                3 : begin
        if (cnt < 317)
        cnt <= cnt + 1'b1;
        cnt <= 9'd0;
        commands <= `BT;
        state <= 4;
                                                4 :        begin
        commands <= `NOP;
        state <= 5;
                                                5 : begin
        //po_read_done <= 1'b1;
        state <= 6;
                                                6 : begin
        commands <= `PREC;
        sdram_addr[10] <= 1'b1;
        state <= 7;
                                                7 : begin
        if (cnt < 2)
        commands <= `NOP;
        cnt <= cnt + 1'b1;
        commands <= `NOP;
        state <= 7;
        cnt <= 0;
                                                default : state <= 0;
                                        endcase
大鹏 发表于 2022-12-9 12:13:19 | 显示全部楼层
sdram读程序实例
大鹏 发表于 2022-12-21 09:56:48 | 显示全部楼层
sdram读程序实例
zxopenhl 发表于 2023-2-2 11:11:46 | 显示全部楼层
sdram读程序实例
GMT+8, 2026-5-22 10:21 , Processed in 0.035149 second(s), 20 queries .
