查看: 1105|回复: 0
sdram写程序实例
fpga_feixiang 发表于 2021-3-18 14:22:44 | 显示全部楼层 |阅读模式
`include "camera_head.v"
module write (pi_clk, pi_rst_n, po_write_bus, pio_sdram_dq, po_wr_fifo_rdreq, pi_wr_fifo_rdata, pi_sdram_addr,
                        po_write_done);
        //system
        input                                        pi_clk;
        input                                        pi_rst_n;
        // sdram
        output                [17:0]                po_write_bus;
        inout                [15:0]                pio_sdram_dq;
        //in data
        output                                        po_wr_fifo_rdreq;
        input                [15:0]                pi_wr_fifo_rdata;
        input                [11:0]                pi_sdram_addr;
        output                                        po_write_done;
        reg                                flag;
        reg                [15:0]        dq_buf;
        assign         pio_sdram_dq = flag ? dq_buf : 16'hzz;
        reg         [3:0]        commands;
        reg                [1:0]        sdram_bank;
        reg                [11:0]        sdram_addr;
        assign        po_write_bus[17:14] = commands;
        assign         po_write_bus[13:12]        = sdram_bank;
        assign        po_write_bus[11:0]         = sdram_addr;
        reg                [2:0]        state;
        reg                [8:0]        cnt;
        reg                                po_write_done;
        reg                                po_wr_fifo_rdreq;
        always @ (posedge pi_clk)
                        if (!pi_rst_n)
                                        state <= 3'd0;
                                        cnt <= 9'd0;
                                        po_write_done <= 1'b0;
                                        po_wr_fifo_rdreq <= 1'b0;
                                        commands <= `NOP;
                                        sdram_bank <= 2'b00;
                                        sdram_addr <= 12'd0;
                                        flag <= 1'b0;
                                        dq_buf <= 16'd0;
                                        case (state)
                                                0 :        begin
        commands <= `ACT;
        sdram_addr <= pi_sdram_addr;
        sdram_bank <= 2'b11;
        po_wr_fifo_rdreq <= 1'b1;
        state <= 1;
                                                1 :        begin
        if (cnt < 1)
        commands <= `NOP;
        cnt <= cnt + 1'b1;
        cnt <= 0;
        commands <= `WR;
        sdram_addr[10] <= 1'b1;
        sdram_addr[8:0] <= 9'd0;
        flag <= 1'b1;
        dq_buf <= pi_wr_fifo_rdata;
        state <= 2;
                                                2 :        begin
        commands <= `NOP;
        //state <= 5;
        if (cnt < 317)
        //if (cnt < 5)
        cnt <= cnt + 1'b1;
        cnt <= 0;
        state <= 3;
                                                3 :        begin
        state <= 4;
                                                4 : begin
        commands <= `BT;
        state <= 5;
                                                5 : begin
        //po_write_done <= 1'b1;
        commands <= `NOP;
        flag <= 1'b0;
        state <= 6;
                                                6 : begin
        commands <= `PREC;
        state <= 7;
                                                7 : begin
        if (cnt < 2)
        commands <= `NOP;
        cnt <= cnt + 1'b1;
        commands <= `NOP;
        state <= 7;
        cnt <= 0;
                                                default : commands <= `NOP;
                                        endcase
GMT+8, 2026-5-22 11:58 , Processed in 0.030954 second(s), 20 queries .
