查看: 1454|回复: 0
iis_capture
fpga_feixiang 发表于 2021-10-14 20:14:14 | 显示全部楼层 |阅读模式
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity iis_capture is
        port(
                reset                :in                std_logic;
                --iis interface
                lrclk                :in                std_logic;
                sclk                :in                std_logic;
                sdi                        :in                std_logic;
                --iis data
                data                ut        std_logic_vector(31 downto 0);
                data_rdy        ut        std_logic;
                test_point        ut        std_logic
end iis_capture;
architecture arch_iis_capture of iis_capture is
signal lr_flag, lr_flag_temp        : std_logic;
signal iis_capture_permit                : std_logic:='0';
signal counter                                        : integer range 63 downto 0;
signal l_ch_valid, r_ch_valid        : std_logic;
signal data_num                                        : integer range 31 downto 0;
signal data_test                                : std_logic_vector(31 downto 0);
process(sclk, reset)
        if reset='1' then
                lr_flag <= '0';
                lr_flag_temp <= '0';
        elsif sclk'event and sclk='1' then
                lr_flag <= lrclk;
                lr_flag_temp <= lr_flag;
        end if;
end process;
iis_capture_permit <= '1' when lr_flag='0' and lr_flag_temp='1';
process(sclk, reset, iis_capture_permit)
        if reset='1' then
                counter <= 0;
        elsif (sclk'event and sclk='1') and iis_capture_permit='1' then
                if counter = 63 then -- 64 sclk [0~63] per cycle
                        counter <= 0; -- counter is 0 at 64th [zeroth] sclk rising edge
                        counter <= counter + 1;
                end if;
        end if;
end        process;
l_ch_valid <= '1' when counter>=0 and counter<=15 else
              '0';
r_ch_valid <= '1' when counter>=32 and counter<=47 else
              '0';
        if reset='1' then
                data <= X"0000_0000";
                if l_ch_valid='1' or r_ch_valid='1' then
                        data(data_num) <= sdi;
                        data_test(data_num) <= sdi;
                end if;
        end if;
end process;
data_num <= 31 - counter when l_ch_valid='1' else
            47 - counter when r_ch_valid='1' else
                        0;
data_rdy <= '1' when counter=48 else
            '0';
test_point <= iis_capture_permit;
end arch_iis_capture;
GMT+8, 2026-5-22 11:12 , Processed in 0.030701 second(s), 20 queries .
