查看: 1449|回复: 0
crc3
fpga_feixiang 发表于 2021-10-14 20:16:53 | 显示全部楼层 |阅读模式
`timescale 1ns/1ns
module crc3;
reg clk,rst_n;
initial begin
clk=0;
rst_n=0;
#53 rst_n=1;
always #2 clk=~clk;
reg [7:0]data_fm;
reg [7:0] cnt;
           if(~rst_n)
                        cnt<=8'd0;
                        cnt<=cnt+1'b1;
           if(~rst_n)
                        data_fm<={$random}%256;
           else if(cnt==8'hFF)
reg [0:0]data;
reg en_crc;
           if(~rst_n)begin
                        en_crc<=1'b0;
                        data<=1'b0;end
           else case(cnt)
                        8'd2 :begin en_crc<=1'b1;data<=data_fm[7];end
                        8'd3 :begin en_crc<=1'b1;data<=data_fm[6];end
                        8'd4 :begin en_crc<=1'b1;data<=data_fm[5];end
                        8'd5 :begin en_crc<=1'b1;data<=data_fm[4];end
                        8'd6 :begin en_crc<=1'b1;data<=data_fm[3];end
                        8'd7 :begin en_crc<=1'b1;data<=data_fm[2];end
                        8'd8 :begin en_crc<=1'b1;data<=data_fm[1];end
                        8'd9 :begin en_crc<=1'b1;data<=data_fm[0];end
                        default:en_crc<=1'b0;
                endcase
wire [2:0]crc_tb;
reg [7:0]num_tb;
           if(~rst_n)
                        num_tb<=8'd0;
           else if(cnt==8'hFF)
                        num_tb<=num_tb+1'b1;
integer fid;
initial fid=$fopen("CRC_DATA.DAT");
always @(posedge clk)
           if(cnt==8'd11)
                        $fdisplay(fid,"SDATA=%0h \tDb=%0b \tDh=%0h \tDd=%0d",data_fm ,crc_tb,crc_tb,crc_tb);
           if(num_tb>8'd99) begin
                $fclose(fid);
                $stop;
//**************CRC计算*****************************************************
parameter CRC_INIT=3'b101;
reg [2:0]crc_current;
wire [2:0] crc_next;//G(X)=1101
assign crc_tb=crc_current;
           if(~rst_n)
                        crc_current<=CRC_INIT;
           else if(en_crc)
                        crc_current<=crc_next;
wire   feedback;
assign feedback=data[0]^crc_current[2];
assign crc_next[0]=(feedback*1'b1)  ^1'b0;
assign crc_next[1]=(feedback*1'b0)  ^crc_current[0];
assign crc_next[2]=(feedback*1'b1)  ^crc_current[1];
GMT+8, 2026-5-22 11:02 , Processed in 0.031858 second(s), 20 queries .
