查看: 1309|回复: 0
audio_QPSK_dem.v
fpga_feixiang 发表于 2022-3-8 18:12:09 | 显示全部楼层 |阅读模式
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 2021/12/28 16:56:28
// Design Name:
// Module Name: audio_QPSK_dem
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module audio_QPSK_dem(
    input         clk,                   //36MHz
    input         rst,
    input  [15:0] data_in_I,
    input  [15:0] data_in_Q,
    input         data_in_valid,
    input  [11:0] count,
        input         rx_axis_tready,        //1ms assert once.
        output [15:0] data_out,
    output        data_out_valid,
    output [1:0]  axis_tkeep,
    output        axis_tlast
    reg [4:0]  cnt16;
    reg        data_en;
    reg        data_en_dly1;
    reg [15:0] data_in_I_dly1;
    // reg [11:0] data_in_Q_dly1;
    reg        data_in_valid_dly1;
    reg        data_out_valid_temp;
    reg        data_out_temp_i;
    // reg        data_out_temp_q;
    reg [4:0]  cnt16_dly1;
    wire       data_start;
    wire       parallel_data_ready;
    reg [15:0] data_shift;
    reg [15:0] data_out_temp;
    reg        valid_out_temp;
    reg [4:0]  cnt32;
    always @(posedge clk) begin
        if (rst) begin
            cnt16 <= 5'd0;
        else if (data_in_valid && cnt16 == 5'd16) begin
            cnt16 <= 5'd0;
        else if (data_in_valid && count == 12'd127) begin
            cnt16 <= 5'd1;
        else if (data_in_valid && |cnt16) begin
            cnt16 <= cnt16 + 1'b1;
        if (rst) begin
            data_en <= 1'b0;
            data_en <= 1'b1;
            data_en <= 1'b0;
        data_in_I_dly1     <= data_in_I;
        // data_in_Q_dly1     <= data_in_Q;
        data_in_valid_dly1 <= data_in_valid;
        if (rst) begin
            data_out_temp_i <= 1'b0;
        else if (data_in_valid_dly1 && data_en && ((data_in_I_dly1[15] == 1'b0 && data_in_I_dly1[14:0] > 15'd50) || (data_in_I_dly1[15] == 1'b1 && data_in_I_dly1[14:0] < 15'd32717))) begin
            case ({data_in_I_dly1[15]})
                1'b0: begin
                    data_out_temp_i <= 1'b1;
                default : begin
            endcase
        else begin
        if (rst) begin
            data_out_valid_temp <= 1'b0;
        else if (data_en && data_in_valid_dly1) begin
            data_out_valid_temp <= 1'b1;
        else begin
        data_en_dly1 <= data_en;
        cnt16_dly1   <= cnt16;
    assign data_start = (data_en && ~data_en_dly1) ? 1'b1 : 1'b0;
    assign parallel_data_ready = (~data_en && data_en_dly1) ? 1'b1 : 1'b0;
        if (rst) begin
            data_shift <= 16'd0;
        else if (data_start) begin
        else if (~data_en_dly1) begin
        else if (data_en_dly1 && data_out_valid_temp) begin
            case (cnt16_dly1)
                5'd1:  data_shift <= {data_shift[15:1],data_out_temp_i};
                5'd2:  data_shift <= {data_shift[15:2],data_out_temp_i,data_shift[0]};
                5'd3:  data_shift <= {data_shift[15:3],data_out_temp_i,data_shift[1:0]};
                5'd4:  data_shift <= {data_shift[15:4],data_out_temp_i,data_shift[2:0]};
                5'd5:  data_shift <= {data_shift[15:5],data_out_temp_i,data_shift[3:0]};
                5'd6:  data_shift <= {data_shift[15:6],data_out_temp_i,data_shift[4:0]};
                5'd7:  data_shift <= {data_shift[15:7],data_out_temp_i,data_shift[5:0]};
                5'd8:  data_shift <= {data_shift[15:8],data_out_temp_i,data_shift[6:0]};
                5'd9:  data_shift <= {data_shift[15:9],data_out_temp_i,data_shift[7:0]};
                5'd10: data_shift <= {data_shift[15:10],data_out_temp_i,data_shift[8:0]};
                5'd11: data_shift <= {data_shift[15:11],data_out_temp_i,data_shift[9:0]};
                5'd12: data_shift <= {data_shift[15:12],data_out_temp_i,data_shift[10:0]};
                5'd13: data_shift <= {data_shift[15:13],data_out_temp_i,data_shift[11:0]};
                5'd14: data_shift <= {data_shift[15:14],data_out_temp_i,data_shift[12:0]};
                5'd15: data_shift <= {data_shift[15],data_out_temp_i,data_shift[13:0]};
                5'd16: data_shift <= {data_out_temp_i,data_shift[14:0]};
                default : data_shift <= 16'd0;
            endcase
        if (rst) begin
            data_out_temp <= 16'd0;
        else     if (data_en_dly1 && data_out_valid_temp  && (cnt16_dly1==5'd16))   //if (parallel_data_ready )begin//&& rx_axis_tready) begin
            data_out_temp <= {data_out_temp_i,data_shift[14:0]};
                        if(rst)
                                        valid_out_temp<=1'b0;
                        else  if(parallel_data_ready)
                                        valid_out_temp                      <= 1'b1;//parallel_data_ready && rx_axis_tready;
                        else if(rx_axis_tready)
        if (rst) begin
            cnt32                   <= 5'd0;
        else if (valid_out_temp && rx_axis_tready) begin
            cnt32                   <= cnt32 + 1'b1;
    assign axis_tlast = (cnt32 == 5'd31) ? 1'b1 : 1'b0;
    // always @(posedge clk) begin
    //     if (rx_axis_tready) begin
    //         valid_out_temp <= parallel_data_ready;
    //     end
    //     else if (parallel_data_ready) begin
    //      valid_out_temp <= 1'b1;
    //     end
    // end
    assign data_out       = data_out_temp;
    assign data_out_valid = valid_out_temp;
    assign axis_tkeep     = 2'b11;
GMT+8, 2026-5-22 10:21 , Processed in 0.031984 second(s), 20 queries .
