查看: 1515|回复: 0
axi_interface_slave.v
fpga_feixiang 发表于 2022-3-8 18:12:41 | 显示全部楼层 |阅读模式
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 2022/01/20 10:22:04
// Design Name:
// Module Name: axi_interface_slave
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module axi_interface_slave(
    input                   clk,
    input                   rst,
    input         [15:0]    axis_tdata,
    output                  axis_tready,
    input                   axis_tvalid,
        input                   data_re,
    output                  data_out_i,
    output                  data_out_q
    reg [15:0] data_reg;
    reg        valid_reg;
    reg [8:0]  cnt512;
    reg [15:0] data_shift_i;
    reg [15:0] data_shift_q;
    reg        axis_tvalid_dly1;
    reg        data_1bit_valid;
    assign axis_tready = data_re;
    always @(posedge clk) begin
        if (rst) begin
            data_reg <= 16'd0;
        else if (axis_tvalid && axis_tready) begin
            data_reg <= axis_tdata;
        else begin
            data_reg <= data_reg;
                if(rst)
                        valid_reg<=1'b0;
                else if( axis_tready && axis_tvalid)
                        valid_reg <=1'b1;
                        valid_reg<=1'b0;
//--------------------parallel to serial---------------------------
        if (rst) begin
            cnt512 <= 9'd0;
        else if (valid_reg) begin
            cnt512 <= 9'd0;
        else if (cnt512 == 9'd511) begin
            cnt512 <= cnt512;
        else begin
            cnt512 <= cnt512 + 1'b1;
        if (rst) begin
            data_shift_i <= 16'd0;
            data_shift_i <= data_reg;
        else if (cnt512[4:0] == 5'd31) begin
            data_shift_i <= {data_shift_i[0],data_shift_i[15:1]};      // from low to high
        if (rst) begin
            data_shift_q <= 16'd0;
            data_shift_q <= {data_shift_q[0],data_shift_q[15:1]};      // from low to high
    assign data_out_i = data_shift_i[0];
    assign data_out_q = data_shift_q[0];
GMT+8, 2026-5-22 09:33 , Processed in 0.031682 second(s), 20 queries .
