查看: 1961|回复: 0
sram读写
ryh619 发表于 2011-8-30 13:54:47 | 显示全部楼层 |阅读模式
实现功能:en=1时,data_lcd<=data_ram即从ram向lcd读数据;当en=0时,data_ram<=data_reg;从寄存器向ram写数据,读写数据控制信号和地址信号略去,只考虑数据信号,时序仿真时:found logic contention at XXns on node XX警告,时序仿真结果也不对,如图,本人新手,各位大侠指导下子程序如何改正。
library ieee;
use ieee.std_logic_1164.all;
entity sx is
port(en:in std_logic;
     data_reg:in std_logic_vector(7 downto 0);
     data_lcdut std_logic_vector(7 downto 0);
     data_ram:inout std_logic_vector(7 downto 0));
end sx;
architecture art of sx is
process(en,data_reg,data_ram)is
case en is
when '0'=>data_ram<=data_reg;
when'1'=>data_lcd<=data_ram;
when others=>data_ram<=(others=>'Z');
end case;
end process;
end art;
GMT+8, 2026-5-23 21:20 , Processed in 0.031940 second(s), 21 queries .
