查看: 1245|回复: 2
如何将自己写的verilog模块封装成IP核
dameihuaxia 发表于 2022-7-11 14:19:04 | 显示全部楼层 |阅读模式
平台与材料
一个写好的工程,综合通过,不用布局布线,ISE或Vivado皆可。如果是ISE,需要在properties里取消选中 iobuf 。这样就只能被当做内部模块调用了。
Vivado
步骤
打开Vivado,创建一个工程
Tools -> Create or package IP
里面有三个选项,分别是打包本工程,打包本工程的一个Design,打包一个目录下的工程。
一般会选第三个。
在该目录下,应该有一个Vivado或者ISE工程,综合通过了的。
选择完打包的目录后,选择Automatically select top module。
一般都能选择到正确的top module,如果选错了,先查看文件是否全部导入,如果全部导入了还选错顶层模块,那就右键手动set as top。
这个时候在右上侧的代码视窗里应该出现了配置IP核的选项,有好几种,慢慢选,完了在最后一栏检查有没错漏,然后点package IP。
然后IP就生成好了,在Block Design的原理图视窗右键add IP,就能找到你刚刚打包的IP了。
官方解释:
Description
There is a black-box submodule in the design which is fed with an EDIF/NGC netlist. The following errors and warnings are issued during Translate:
"ERROR:NgdBuild:770 - IBUF 'b_IBUF' and IBUF 'b_ibuf' on net 'b_IBUF' are linedup in series. Buffers of the same direction cannot be placed in series.
WARNING:NgdBuild:463 - input pad net 'b_IBUF' has an illegal input buffer
ERROR:NgdBuild:925 - input net 'b_IBUF' is connected to the incorrect side ofbuffer(s):
pin O on block b_IBUF with type IBUF
ERROR:NgdBuild:924 - input pad net 'clk_BUFGP' is driving non-buffer primitives:
pin C on block h with type FDR, pin C on block g with type FD, pin O on block clk_BUFGP/BUFG with type BUFG
ERROR:NgdBuild:809 - output pad net 'e' has an illegal load:
pin I1 on block Mxor_g_xor0000_Result1 with type LUT2
ERROR:NgdBuild:455 - logical net 'h' has multiple driver(s):
pin Q on block h with type FDR, pin PAD on block h.PAD with type PAD"
How can I resolve these errors?
Solution
These errors are issued because the submodule EDIF/NGC netlist contains IBUFs/OBUFs. XST also adds IBUFs and OBUFs to the top level, so that they are lined up or the pads are driving/being driven by non-buffer components.
When an EDIF/NGC netlist is used as a submodule of another design, the following conditions must be met:
If the input/output ports of the submodule are connected to the top module ports directly, like port1in the following figure, the IBUFs/OBUFs can be put in the submodule,but theXST property "Read Cores"has tobe checked. Then,XSTwill read the netlistin the project directory or a location specified in "Cores Search Directories" and will not add extra IBUFs/OBUFs on these top level ports.
If theinput/output ports of the submodule are NOT connected to the top module ports directly, like port2 inthe following figure, the IBUFs/OBUFs must not be put in the submodule.
The following are some solutions to this problem.
Disable IBUF/OBUF insertion when you generate the submodule netlist. Add all IBUFs/OBUFsto the top level.
For XST, go to Synthesis Properties -> Xilinx Specific Options -> uncheck "Add I/O Buffers"
For Synplify Pro, go to Implementation Options -> Device tab -> check "Disable I/O Insertion"
Selectively disableIBUF/OBUF insertion onthe input/output ports that are NOT connected to the top module ports directly.
For XST, use "buffer_type" constraint. Please refer to XST User Guide.
For Synplify Pro, refer to (Xilinx Answer 4508).
If theIBUF/OBUFs are instantiated in the submodule, disablingIBUF/OBUF insertiondoes not remove the buffers from the submodule. If this is the case, remove theIBUF/OBUFs instantaiation from the submodule and instantiate them in the top level.
LYF 发表于 2022-7-11 14:25:28 | 显示全部楼层
http://www.fpgaw.com/forum.php?m ... 7&fromuid=59610
(出处: fpga论坛|fpga设计论坛)
嘿哈嘿哈哈 发表于 2022-12-11 09:13:27 | 显示全部楼层
GMT+8, 2026-5-23 22:53 , Processed in 0.032134 second(s), 19 queries .
