查看: 1635|回复: 0
请问下面的函数代表什么功能?
jiyuhl 发表于 2011-9-1 20:17:07 | 显示全部楼层 |阅读模式
unsigned int NF_search(unsigned int b_addr)
  unsigned char tempchar,bit_offset;
  unsigned int byte_offset;
  while(1){
  byte_offset=(unsigned int)b_addr/8;
  bit_offset=(unsigned char)b_addr%8;
    tempchar=invalidtab[byte_offset];
    while(bit_offset!=0){ tempchar=tempchar>>1;bit_offset--; }
        tempchar&=0x01;
    if(tempchar!=0x00){ return b_addr;}
        b_addr++;
        if (b_addr==4095) return 0;
GMT+8, 2026-5-23 22:13 , Processed in 0.033258 second(s), 22 queries .
