查看: 12308|回复: 4
Signal Tap II探测信号时,总是显示“Waiting for clock",为何呢?
ccs 发表于 2010-5-6 13:01:49 | 显示全部楼层 |阅读模式
module test3(
  clk,
  reset,
  en,
  z0_in,
  z0_out);
input clk;
input reset;
input en;
input [19:0] z0_in;
output [19:0] z0_out;
reg [19:0] z0_out;
reg [19:0] z0_in_temp;
always @(posedge clk or posedge reset)
    if(reset)
        z0_out <= 0;
        z0_in_temp <= 0;
        if(en)
            z0_in_temp <= z0_in;
            z0_in_temp <= z0_in_temp;
        if(-20'd131072<=z0_in_temp && z0_in_temp<=20'd131072)
            z0_out <= z0_in_temp;
        if(20'd131072<z0_in_temp && z0_in_temp<20'd262144)
            z0_out <= z0_in_temp - 20'd262144;
        if(-20'd262144<z0_in_temp && z0_in_temp<-20'd131072)
            z0_out <= z0_in_temp + 20'd262144;
xinu2009 发表于 2010-5-6 15:35:41 | 显示全部楼层
是不是用Signal Tap II采样中间或输出信号的时候没有设置采样时钟啊?
xinu2009 发表于 2010-5-6 15:37:23 | 显示全部楼层
使用逻辑分析仪观测信号的时候是要设置一个采样时钟的,一般就是你系统中时钟频率最大的一个(具体可以看情况而定)!还要设置采样点数!
xinu2009 发表于 2010-5-6 15:43:26 | 显示全部楼层
Sunlife 发表于 2015-4-7 11:34:22 | 显示全部楼层
GMT+8, 2026-5-23 10:32 , Processed in 0.033842 second(s), 20 queries .
