查看: 3001|回复: 0
VHDL报错:loop must terminate within 10,000 iteration???
yu_hai_yang 发表于 2011-9-14 09:56:33 | 显示全部楼层 |阅读模式
LIBRARY IEEE;--库声明
USE IEEE.STD_LOGIC_1164.ALL;--程序包说明
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY Cycle_Use IS  --实体描述
        PORT
                a,Clock : IN STD_LOGIC;
                v:  OUT STD_LOGIC
END Cycle_Use;
ARCHITECTURE Done OF Cycle_Use IS --结构体说明
SIGNAL  b :  INTEGER RANGE 0 TO 10000000;
BEGIN
yyy : PROCESS(a)
          BEGIN
          b<=0;
          IF a='1' THEN
          LOOP
      b<=b+1;
      EXIT WHEN b>10;
      END LOOP;
      v<='1';
      END IF;
      END PROCESS yyy;
END Done;
--Error (10536): VHDL Loop Statement error at Cycle_Use.vhd(18): loop must terminate within 10,000 iterations
--Error: Can't elaborate top-level user hierarchy
请高手指点一下:EP1C6Q240C8,我用的LOOP  EXIT WHEN 为什么报这样的错误
GMT+8, 2026-5-23 21:59 , Processed in 0.032411 second(s), 21 queries .
