查看: 2570|回复: 1
NiosII IDE 9.0 bug-Cyclone III Nios can't not boot up from EPCS device
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-7 09:43:24 | 显示全部楼层 |阅读模式
想把NiosII的用户程序下载到CycloneIII上,折腾了好久没下进去,最后发现这是Altera的bug,火大了
发给大家看看,希望没人在此耽误功夫
Problem
Why does my Cyclone III Nios II system not boot up from an EPCS device when I program the EPCS with Flash Programmer ver.9.0?
Solution
Nios® II embedded processor executable code is not correctly programmed on an EPCS device with version 9.0 and 9.0sp1 Nios II Flash Programmer tool chain.
Version 9.0 and 9.0sp1 contain a bug in the tool chain. To solve this problem, contact Altera® technical support via mySupport to request the Nios II EDS 1.01 patch.
This problem will be fixed by Nios II EDS version 9.0sp2 .
Altera网站上的support:
http://www.altera.com/support/kdb/solutions/rd06022009_270.html
Sunlife 发表于 2015-4-7 11:35:28 | 显示全部楼层
GMT+8, 2026-5-23 10:28 , Processed in 0.042201 second(s), 23 queries .
