查看: 3166|回复: 1
rom被忽略了。。求助啊。。。。
xiaoyuer 发表于 2011-10-16 15:54:24 | 显示全部楼层 |阅读模式
Warning: Synthesized away the following RAM node(s):
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[0]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[1]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[2]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[3]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[4]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[5]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[6]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[7]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[8]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[9]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[10]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[11]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[12]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[13]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[14]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[15]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[16]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[17]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[18]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[19]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[20]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[21]"
                Warning (14320): Synthesized away node "pika_rgb:U8|altsyncram:altsyncram_component|altsyncram_vt81:auto_generated|q_a[22]"。。。。。。。
哪位大神帮我看看啊。。。。。急死了。。。
jahero 发表于 2011-10-29 23:00:20 | 显示全部楼层
有可能你把ip核的例化文件删改了 你的rom最好重新做
GMT+8, 2026-5-23 22:08 , Processed in 0.051215 second(s), 21 queries .
