查看: 1560|回复: 2
仿真信号生成问题
x2007100154 发表于 2011-10-16 16:00:13 | 显示全部楼层 |阅读模式
library ieee;
   use ieee.std_logic_1164.all;
   entity test_fadder is
   end entity test_fadder;
   architecture arc1 of test_fadder is
   component f_adder
  port(ain,bin: in std_logic;
       cin: in std_logic;
       sum,cout: out std_logic);
end component;
signal test_a,test_b,test_c: std_logic;
signal test_co,test_s: std_logic;
u0:f_adder port map(ain=>test_a,bin=>test_b,cin=>test_c,
cout=>test_co,sum=>test_s);
process
test_a<='0';
wait for 400 ns;
test_a<='1';
wait for 400 ns;
test_a<='0';
wait for 200 ns;
test_a<='1';
wait for 1000 ns;
test_a<='0';
wait ;
end process;
process
test_b<='0';
wait for 500 ns;
test_b<='1';
wait for 800 ns;
test_b<='0';
wait ;
end process;
process
test_c<='0';
wait for 400 ns;
test_c<='1';
wait for 700 ns;
test_c<='0';
wait for 400 ns;
test_c<='1';
wait for 600 ns;
test_c<='0';
wait;
end process;
end;
我是以程序直接产生的方法生成仿真输入信号的,为什么点击时序仿真的时候说没有输入信号??顶层实体名为f_adder,请高手指教,,
ok1246 发表于 2011-10-24 16:48:37 | 显示全部楼层
神马东东...
至芯兴洪 发表于 2011-10-28 13:54:22 | 显示全部楼层
用verilog编写个激励测试下,你那搞得很乱
GMT+8, 2026-5-23 22:14 , Processed in 0.042597 second(s), 22 queries .
