查看: 2099|回复: 2
仿真无输出 请教高手
fight 发表于 2011-10-27 23:52:16 | 显示全部楼层 |阅读模式
module pulse_counter_task_logic(
        divide_clk,
        reset_n,
        pulse_pos_input,
        pulse_neg_input,
        pulse_result,
        pre_pulse_pos_1,
        pre_pulse_neg_1,
        input divide_clk;                                //Input Clock to be divided
        input reset_n;                                //Reset
        input pulse_pos_input;      //input pulse positive
        input pulse_neg_input;      //input pulse negative
        output [7:0] pulse_result;    // output pulse counter
        output [7:0]pre_pulse_neg_1;
        output [7:0]pre_pulse_pos_1;
reg [7:0] pulse_result_r;           //output pulse counter register
reg [7:0] pre_pulse_pos;           //pulse counter temporary register
reg [7:0] pre_pulse_neg;
//clock divide Process
always @(posedge divide_clk or negedge reset_n)
        if (~reset_n)
                pulse_result_r <= 8'h0;
        else if (divide_clk)
                pulse_result_r <= pre_pulse_pos + pre_pulse_neg;
            pulse_result_r <= pulse_result_r;
// pulse measure process
always @(negedge pulse_pos_input or posedge divide_clk or negedge reset_n)
        if((~reset_n) | divide_clk )
                pre_pulse_pos <= 8'h0;    //clear the pre_pulse
                pre_pulse_pos <= pre_pulse_pos + 8'h1;
always @(negedge pulse_neg_input or posedge divide_clk or negedge reset_n)
                pre_pulse_neg <= 8'h0;    //clear the pre_pulse
                pre_pulse_neg <= pre_pulse_neg - 8'h1;
assign pulse_result = pulse_result_r;
//assign irq = divide_clk;
assign pre_pulse_pos_1 = pre_pulse_pos;
assign pre_pulse_neg_1 = pre_pulse_neg;
用quartusII自带的仿真器  仿真出来的pulse_result 为什么时钟无输出  请教高手?
ok1246 发表于 2011-11-2 13:23:08 | 显示全部楼层
看不懂。。。
fpga_feixiang 发表于 2022-2-16 14:41:57 | 显示全部楼层
666666666666666666666
GMT+8, 2026-5-24 06:21 , Processed in 0.032313 second(s), 20 queries .
