查看: 739|回复: 2
三伍微SOI开关:GSR1303S 频段2.4G 兼容替代RTC6603
Penny 发表于 2024-4-26 15:39:05 | 显示全部楼层 |阅读模式
GSR1303S: CMOS SOI SPDT Switch
0.1 – 3.0 GHz
Applications
WLAN 802.11a/b/g/n/ac/ax networks
ISM band radios
Low power T/R systems
Features
P0.1dB  +32dBm typical @ +3.3V
Low insertion loss (0.4dB @ 2.5GHz)
High isolation (24dB @ 2.5GHz)
Low DC power consumption
SC-70 6 lead Package (MSL1, 260°C per JEDEC-J-STD-020)
ESD: 1.5 kV HBM on all pins
Description
The GSR1303S is a CMOS SOI single pole dual throw (SPDT) high power switch in a low cost miniature SC-70 6 lead package. The GSR1303S is ideally suited for applications where high power, low insertion loss, and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 3 GHz requiring high power at low control voltage.
雷1314521景 发表于 2024-4-27 17:34:30 | 显示全部楼层
http://www.fpgaw.com/forum.php?m ... 4&fromuid=59831
(出处: 集成电路技术分享)
点评
海!外直播 bitly.net/hvvvvh 禁闻视频 bitly.net/xjjjx 60年,中国做了两件事:一公私合营人民公社.二否定公私合营否定人民公社.前30年,冤假错案超过三千年总和.后30年,贪污腐败超过三千年总和.前30年折腾政治.后30年,   发表于 2024-4-27 19:28
GMT+8, 2026-5-22 10:18 , Processed in 0.031017 second(s), 21 queries .
