查看: 1729|回复: 3
请教有关verilog编写的计时模块的问题。
guo88455648 发表于 2011-11-7 13:14:42 | 显示全部楼层 |阅读模式
自己这段时间学习verilog,编写了一段计时模块的程序,但是编译一直有问题。程序如下:
module clock(clks,RESET,scin,mcin,madd,hadd,sout,mout,hout);
input clks,RESET,madd,hadd;
output scin,mcin;
output [5:0]sout,mout,hout;
reg scin,mcin;
reg[5:0]sout,mout,hout;
always @(posedge clks)
  if(!RESET)  sout<=0;
        if(sout==59)
              sout<=0;
              scin<=0;
              sout<=sout+1;
              scin<=0;
always @(posedge scin or posedge madd)   (问题主要出在这里,如果敏感源只是posedge scin,编译就没有问题,加上posedge madd以后
                                                     编译就不能通过)
  if(!RESET)  mout<=0;
        if(mout==59)
              mout<=0;
              mcin<=0;
              mout<=mout+1;
              mcin<=0;
always @(posedge mcin or posedge hadd)         (此处的问题同上面)
  if(!RESET)  hout<=0;
        if(hout==23)      hout<=0;
        else              hout<=hout+1;
引起出现问题的句子我在上面的程序中已经标注出来了,出现的问题为Error (10200): Verilog HDL Conditional Statement error at clock.v(25):
cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct
请大家帮我解决一下这个问题,谢谢了!
jahero 发表于 2011-11-7 15:30:15 | 显示全部楼层
因为你这么写画不出电路 一个d触发器只有一个边沿触发信号 如果有两个 就要用选通电路选通一下
 楼主| guo88455648 发表于 2011-11-7 19:06:16 | 显示全部楼层
回复 2# jahero
    朋友,能说的详细一些吗
njithjw 发表于 2011-11-7 22:25:34 | 显示全部楼层
module clock
    clks,
    reset,
    scin,
    mcin,
    madd,
    hadd,
    sout,
    mout,
    hout
input           clks;
input           reset;
input           madd;
input           hadd;
output          scin;
output          mcin;
output  [5:0]   sout;
output  [5:0]   mout;
output  [4:0]   hout;
reg             scin;
reg             mcin;
reg     [5:0]   sout;
reg     [5:0]   mout;
reg     [4:0]   hout;
always @ (posedge clks or posedge reset)
    if (reset == 1'b1)
        sout <= 6'd0;
        scin <= 1'b0;
    else if (sout >= 6'd59)
        sout <= 6'd0;
        scin <= 1'b1;
        sout <= sout + 6'd1;
        scin <= 1'b0;
    if (reset == 1'b1)
        mout <= 6'd0;
        mcin <= 1'b0;
    else if ((madd == 1'b1) || (scin == 1'b1))
        if (mout >= 6'd59)
            mout <= 6'd0;
            mcin <= 1'b1;
            mout <= mout + 6'd1;
            mcin <= 1'b0;
    else ;
    if (reset == 1'b1)
        hout <= 5'd0;
    else if ((hadd == 1'b1) || ((scin == 1'b1) && (mcin == 1'b1)))
        if (hout >= 5'd23)
            hout <= 5'd0;
            hout <= hout + 5'd1;
    else ;
GMT+8, 2026-5-23 20:01 , Processed in 0.032402 second(s), 21 queries .
