查看: 1978|回复: 5
郁闷
冉正国 发表于 2011-11-7 21:14:07 | 显示全部楼层 |阅读模式
程序功能不能实现,又找不出原因,郁闷,只能麻烦各位高手看看指点指点了
程序如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity key_test is
        port(start_stop,reset,clk,en: in std_logic;
                 rst: out std_logic;
                 eno: out std_logic);
end key_test;
architecture behav of key_test is
signal station1:std_logic_vector(1 downto 0):="00";
signal station2:std_logic_vector(1 downto 0):="00";
signal sum_tmp:std_logic_vector(3 downto 0);
signal co_tmp:std_logic;
signal rst_tmp:std_logic:='1';
signal eno_tmp:std_logic:='0';
component cnt10_test
        port(reset,en,clk:in std_logic;
                 sum: out std_logic_vector(3 downto 0);
                 co: out std_logic);
end component;
        u0:cnt10_test port map(reset,en,clk,sum_tmp,co_tmp);
        process(reset,co_tmp) is
                if(reset='0') then
                        if(co_tmp'event and co_tmp='1') then
                                case station1 is
                                        when "00"=>station1<="01";
                                        when "01"=>station1<="10";
                                        when "10"=>station1<="11";
                                        when "11"=>station1<="11";
                                        when others=>station1<="00";
                                end case;
                        end if;
                        station1<="00";
                end if;
                if(start_stop'event and start_stop='1') then
                        if(station2="11") then
                                rst_tmp<='0';
                        end if;
                end if;
        end process;
        process(start_stop,co_tmp) is
                if(start_stop='1') then
                                case station2 is
                                        when "00"=>station2<="01";
                                        when "01"=>station2<="10";
                                        when "10"=>station2<="11";
                                        when "11"=>station2<="11";
                                        when others=>station2<="00";
                                end case;
                        end if;
                        station2<="00";
                end if;
                if(start_stop'event and start_stop='0') then
                                eno_tmp<=not eno_tmp;
                        end if;
                end if;
        end process;
        eno<=eno_tmp;
        rst<=rst_tmp;
end behav;
试图将按键去抖动后转变为控制信号,但是reset信号的转换不能实现,望高手不吝赐教
jahero 发表于 2011-11-7 23:30:07 | 显示全部楼层
你把reset改成边沿触发试试
jahero 发表于 2011-11-7 23:31:25 | 显示全部楼层
对了告我一声
 楼主| 冉正国 发表于 2011-11-8 22:49:34 | 显示全部楼层
不好意思,还是不对,还是谢谢你, 我想问问你是不是自带的仿真器与modelsim仿真的结果有差异
jahero 发表于 2011-11-8 23:40:06 | 显示全部楼层
我感觉应该有差异,好像不能综合的语句在quartus里面仿不出来
snowinmoon 发表于 2011-11-10 09:09:00 | 显示全部楼层
建议你把case那块改一下
GMT+8, 2026-5-23 20:01 , Processed in 0.031918 second(s), 20 queries .
