查看: 999|回复: 0
三伍微SOI开关/射频开关:GSR1303S 频段2.4G 兼容替代RTC6603
Penny 发表于 2024-8-28 15:27:44 | 显示全部楼层 |阅读模式
三伍微SOI开关/射频开关:GSR1303S 频段2.4G 兼容替代RTC6603 兼容替代SKY/RTC/KCT/Qorvo
GSR1303S: CMOS SOI SPDT Switch
0.1 – 3.0 GHz
Applications
WLAN 802.11a/b/g/n/ac/ax networks
ISM band radios
Low power T/R systems
Features
P0.1dB  +32dBm typical @ +3.3V
Low insertion loss (0.4dB @ 2.5GHz)
High isolation (24dB @ 2.5GHz)
Low DC power consumption
SC-70 6 lead Package (MSL1, 260°C per JEDEC-J-STD-020)
ESD: 1.5 kV HBM on all pins
Description
The GSR1303S is a CMOS SOI single pole dual throw (SPDT) high power switch in a low cost miniature SC-70 6 lead package.
The GSR1303S is ideally suited for applications where high power, low insertion loss, and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications.
This part can be used in all systems operating up to 3 GHz requiring high power at low control voltage.
GMT+8, 2026-5-22 09:31 , Processed in 0.031111 second(s), 19 queries .
