查看: 6260|回复: 9
ISE12.1使用初体验(问题汇总)
TCL 发表于 2010-5-8 05:47:23 | 显示全部楼层 |阅读模式
ISE12.1报了无数次错误后,装上了,发现没有生成任何快捷方式,开始菜单里也没有
无语啊,我就是Administrator登录的啊,居然无权在All Users 下创建快捷方式?
ISE12.1使用初体验
 楼主| TCL 发表于 2010-5-8 05:48:12 | 显示全部楼层
eda软件安装路径中不要有中文,不要有空格
 楼主| TCL 发表于 2010-5-8 05:48:41 | 显示全部楼层
    安装路径当然不能有中文,但问题是快捷方式的路径是安装程序自己指定的,比如“桌面”这种,它就认为是错误了
 楼主| TCL 发表于 2010-5-8 05:49:12 | 显示全部楼层
    不是这个原因,即没有中文路径,也没有空格
我怀疑是不是中文XP都不行
 楼主| TCL 发表于 2010-5-8 05:49:51 | 显示全部楼层
xilinx 很强大啊,安装软件发布也tnnd不测试啊
可惜了还是用Qt开发环境写的程序,糟蹋Qt的声誉啊
AR #35331 - ISE Design Suite 12 - Shortcuts and desktop icons are not created when language is set to anything other than English or Japanese
Description
My language localization is set to a language other than English or Japanese. After installation, my desktop icons and shortcuts were not created, and the following error occurs:
"Failed to create link xxx.lnk to xxx.xxx"
How can I create the shortcuts and desktop icons?
Solution
Localization settings of English and Japanese are the only supported languages. Any other language setting is not supported and can cause issues with other Xilinx ISE Design Suite tools.
To install the shortcuts and desktop icons, download the following patch and place it into your installed Xilinx directory. Xilinx recommends that you backup your "libwiclient.dll" file prior to dropping the new patch file so that you can revert back if needed. After applying the patch, run shortcutSetup.bat from the Xilinx ISE Design Suite in the common/bin/nt(64) location.
For the patch, download and unzip the file (see the readme file for more information).
Patch: ftp://ftp.xilinx.com/pub/swhelp/ise12_updates/ar35331.zip
 楼主| TCL 发表于 2010-5-8 05:50:32 | 显示全部楼层
网站上还有很多日语文档吗? 日本市场是他们在海外的第一大市场
 楼主| TCL 发表于 2010-5-8 05:51:12 | 显示全部楼层
在linux下装ISE12.1
在linux下装ISE12.1,发现settings32.sh有问题,居然PATH都加错了,怀疑发布前到底有没有测试过场
 楼主| TCL 发表于 2010-5-8 05:52:09 | 显示全部楼层
和你一样,
不过试验了一下,
自己设置环境变量后,
在bin/nt下找到对应的l.exe文件,
提示,sysgen被挪到了ise目录下,还以为没装上呢。
还是可以正常启动的,
跑了个小程序,应该问题不大。
xilinx的软件部门太弱了,
每次软件那么大,还一堆bug。
本以为11.1表现的还不错。
结果在ISE12.1又这样。
lpyuanyuan 发表于 2010-5-11 22:58:39 | 显示全部楼层
ISE版本的更新速度
呵呵,你看ISE版本的更新速度就知道啦。。。
ISE11.2到ISE11.4用了不到半年时间,至少在我们使用了ISE11.2后半年不到,技术支持就建议更换ISE11.4了。。
这几天发现有些莫名其妙的问题,技术支持说ISE11.4有些已知的问题,又建议换ISE12.1了。。郁闷啊
IPO 发表于 2010-8-5 08:07:00 | 显示全部楼层
ISE12.1感觉不错
GMT+8, 2026-5-24 05:39 , Processed in 0.041046 second(s), 20 queries .
