查看: 475|回复: 0
三伍微电子GSR2406 IoT FEM 2.4G PA 射频前端模组芯片
Penny 发表于 2025-8-13 15:25:06 | 显示全部楼层 |阅读模式
三伍微电子GSR2406 IoT FEM 2.4G PA 射频前端模组芯片规格书
Product Description
     The GSR2406 is a high-performance, fully integrated RF front-end module (FEM) designed for Zigbee technology, Thread, and Bluetooth (including low energy) applications.
    The GSR2406 is designed for ease of use and maximum flexibility. The device provides a power amplifier, low-noise amplifier, low-loss bypass path, transmit/receive switches, and controls compatible with 1.8 V to 3.6 V levels.
   The RF blocks operate over a wide supply voltage range from 2.5V to 5 V that allows the GSR2406 to be used in battery powered applications over a wide spectrum of the battery discharge curve.
   The device is provided in a compact, 12-pin1.9 x1.9 mm small package. Pin map is shown in Figure 1. A functional block diagram is shown in Figure 2.
Key Features
*   Integrated PA with +14.5 dBm output power
*  Integrated bypass path
*  1.8 dB LNA Noise Figure
*  Single-ended transmit/receive interface
*  Supply range: 2.5 V to 5 V
*  Sleep mode current: < 1 μA typical
*   No external bias resistor is required
Applications
*   In-home appliances
*   Smart thermostats
*  Range extender
*   Wireless audio
*   Internet of Things (IoT) devices
GMT+8, 2026-5-22 08:03 , Processed in 0.031542 second(s), 19 queries .
