查看: 1243|回复: 1
哪位牛人帮我看看我的VHDL程序哪里有问题?
开心果 发表于 2011-11-30 16:47:36 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
entity desplay is
port(
        indate:in integer range 0 to 9;
        inadd:in integer range 1 to 8;
        outdateut std_logic_vector(7 downto 0);
        outaddut std_logic_vector(7 downto 0));
end desplay;
architecture behave of desplay is
U1:        process(indate)
                case indate is
                        when 0 =>outdate<=x"c0";----0
                        when 1 =>outdate<=x"f9";----1
                        when 2 =>outdate<=x"a4";----2
                        when 3 =>outdate<=x"b0";----3
                        when 4 =>outdate<=x"99";----4
                        when 5 =>outdate<=x"92";----5
                        when 6 =>outdate<=x"82";----6
                        when 7 =>outdate<=x"f8";----7
                        when 8 =>outdate<=x"80";----8
                        when 9 =>outdate<=x"90";----9
                        when others =>outdate<=x"ff";
                end case;
        end process;
U2:        process(inadd)
                        case inadd is
                                when 1 =>outadd<="00000001";
                                when 2 =>outadd<="00000010";
                                when 3 =>outadd<="00000100";
                                when 4 =>outadd<="00001000";
                                when 5 =>outadd<="00010000";
                                when 6 =>outadd<="00100000";
                                when 7 =>outadd<="01000000";
                                when 8 =>outadd<="10000000";
                                when others =>outadd<="11111111";
                        end case;
        end process;
end behave;
library ieee;
entity smg is
        port(
                outadd ut std_logic_vector(7 downto 0);
end smg;
architecture art of smg is
component desplay
port(
end component desplay;
u1: desplay port map(2,5,outdate,outadd);
end art;
用Quartus仿真出得结果却是
这个程序只是一个简单的数码管显示的程序,只不过我想用元件例化做
I2C 发表于 2011-12-3 03:52:33 | 显示全部楼层
GMT+8, 2026-5-23 21:15 , Processed in 0.033207 second(s), 21 queries .
