查看: 1560|回复: 4
一个ds18b20的verilog程序,提示有错误,大家帮忙看一下
jwx1904 发表于 2011-12-25 17:04:25 | 显示全部楼层 |阅读模式
module temperature (clk,dq,
d,cont,temp
input clk;//时钟1MHZ
input dq;//数字温度串行输入端口
output d;//控制信号输出端口
output cont;//三态门控制信号
output [9:0] temp;//10为温度值并行输出端口
reg d;
reg cont;
reg [9:0] temp;
reg data;
reg [6:0] num;//时隙计数,70个时钟周期为一个时隙
reg [6:0] count;//一次温度转换和输出技术,70个时隙
reg [9:0] t;
always @(posedge clk)
num = num + 1 ;
if (num > 7'b1000100)
begin num = 7'b0000000;
if (count == 7'b1001011)
begin count = 7'b0000000 ; end
begin count = count + 1 ; end
begin num = num + 1 ; end
if (count >= 7'b0000000 && count <= 7'b0000110)//reset脉冲
begin data = 0 ; cont = 0 ; end
else if (count > 7'b0000110 && count <= 7'b0001101)//presenc脉冲
begin cont = 0 ; end
else if (count == 7'b0001110 || count == 7'b0001111 || count == 7'b0010010 || count == 7'b0010011) ;//skip‘0’空隙
if (num >= 7'b0000000 && num < 7'b0111100)
begin data = 0 ; cont = 1 ; end
else if (count == 7'b0010000 || count == 7'b0010001 || count == 7'b0010100 || count == 7'b0010101) ;
if (num >= 7'b0000000 && num < 7'b0001010)
else if (count == 7'b0010110 || count == 7'b0010111 || count == 7'b0011001 || count == 7'b0011010 || count == 7'b0011011 || count == 'b0011101) ;//convert'0'
if (num >= 'b0000000 && num < 'b0111100)
else if (count == 'b0011000 && count == 'b0011100)
if (num >= 'b0000000 && num < 'b00011100)
else if (count == 'b0011110 && count == 'b0100100)//reste
else if (count == 'b0100101 && count == 'b0101011)//presence
 楼主| jwx1904 发表于 2011-12-25 20:56:52 | 显示全部楼层
提示的就是图片里的错误,不过我分析不来,感觉不应该是这个啊
 楼主| jwx1904 发表于 2011-12-25 21:00:52 | 显示全部楼层
哪位大哥帮忙编译一下,看看错误,谢谢
白开水的噩梦 发表于 2011-12-26 14:14:22 | 显示全部楼层
module temperature (clk,dq,d,cont,temp);
input clk;//时钟1MHZ
output d;//控制信号输出端口
reg d;
reg cont;
reg [9:0] temp;
reg data;
reg [9:0] t;
num = num + 1 ;
        num = 7'b0000000;
else if (count == 7'b0001110 || count == 7'b0001111 || count == 7'b0010010 || count == 7'b0010011) //skip‘0’空隙
else if (count == 7'b0010110 || count == 7'b0010111 || count == 7'b0011001 || count == 7'b0011010 || count == 7'b0011011 || count == 'b0011101) //convert'0'
改好了,编译通过
白开水的噩梦 发表于 2011-12-26 14:14:42 | 显示全部楼层
你只是犯了点小错误
GMT+8, 2026-5-23 20:05 , Processed in 0.046154 second(s), 22 queries .
