查看: 2157|回复: 2
求高手帮我找下这个滤波器设计中的错误 有一处小错误
qq376784106 发表于 2010-5-12 12:38:58 | 显示全部楼层 |阅读模式
module FIR_Gaussian_Lowpass(Data_out,Data_in,clock,reset,test,result9);
//8阶高斯低通FIR
parameter order = 8;
parameter word_size_in = 8;
parameter word_size_out = 2*word_size_in + 2;
parameter b0 = 8'd7;
parameter b1 = 8'd17;
parameter b2 = 8'd32;
parameter b3 = 8'd46;
parameter b4 = 8'd52;
parameter b5 = 8'd46;
parameter b6 = 8'd32;
parameter b7 = 8'd17;
parameter b8 = 8'd7;
parameter H = 1'b1,L = 1'b0;
output [word_size_out -1 : 0]  Data_out;
input  [word_size_in -1 : 0]  Data_in;
input        clock,reset;
reg  [word_size_in -1 : 0] Samples[1rder];
output  [63:0] test;
output [15:0] result9;
integer k;
//multip mult1(.datain1(b0),.datain2(Data_in),.clock(clock),.result(Data_out1));
/*assign data_out = b0*Data_in
     +b1*Samples[1]
     +b2*Samples[2]
     +b3*Samples[3]
     +b4*Samples[4]
     +b5*Samples[5]
     +b6*Samples[6]
     +b7*Samples[7]
     +b8*Samples[8];*/
/*assign data_out = result0
     +result1
     +result2
     +result3
     +result4
     +result5
     +result6
     +result7
     +result8;*/
adder16X1 (
   data0x,data10x,
   data11x,data12x,
   data13x,data14x,
   data15x,data1x,
   data2x,data3x,
   data4x,data5x,
   data6x,data7x,
   data8x,data9x,
   result
adder add1 (.data0x(result0),.data1x(result1),
  .data2x(result2),.data3x(result3),
  .data4x(result4),.data5x(result5),
  .data6x(result6),.data7x(result7),
  .result(result9));
adder add2 (.data0x(result8),.data1x(result9),
  .data2x(8'h00),.data3x(8'h00),
  .data4x(8'h00),.data5x(8'h00),
  .data6x(8'h00),.data7x(8'h00),
  .result(result10));
assign test = {Samples[1],Samples[2],Samples[3],Samples[4],
    Samples[5],Samples[6],Samples[7],Samples[8]};
wire [7:0] result0;
wire [7:0] result1;
wire [7:0] result2;
wire [7:0] result3;
wire [7:0] result4;
wire [7:0] result5;
wire [7:0] result6;
wire [7:0] result7;
wire [7:0] result8;
wire [15:0] result9;
wire [15:0] result10;
assign data_out = result9;
multiplex mult1(.dataa(b0),.datab(Data_in),.result(result0));
multiplex mult2(.dataa(b1),.datab(Samples[1]),.result(result1));
multiplex mult3(.dataa(b2),.datab(Samples[2]),.result(result2));
multiplex mult4(.dataa(b3),.datab(Samples[3]),.result(result3));
multiplex mult5(.dataa(b4),.datab(Samples[4]),.result(result4));
multiplex mult6(.dataa(b5),.datab(Samples[5]),.result(result5));
multiplex mult7(.dataa(b6),.datab(Samples[6]),.result(result6));
multiplex mult8(.dataa(b7),.datab(Samples[7]),.result(result7));
multiplex mult9(.dataa(b8),.datab(Samples[8]),.result(result8));
always @(posedge clock)
if(reset == H)
   /*for(k=1;k<=order;k=k+1)
    Samples[k] <= 0;*/
   Samples[1] <= 0;
   Samples[2] <= 0;
   Samples[3] <= 0;
   Samples[4] <= 0;
   Samples[5] <= 0;
   Samples[6] <= 0;
   Samples[7] <= 0;
   Samples[8] <= 0;
   Samples[1] <= Data_in;
   /*for(k=2;k<=order;k=k+1)
    Samples[k] <= Samples[k-1];*/
   Samples[2] <= Samples[1] ;
   Samples[3] <= Samples[2] ;
   Samples[4] <= Samples[3] ;
   Samples[5] <= Samples[4] ;
   Samples[6] <= Samples[5] ;
   Samples[7] <= Samples[6] ;
   Samples[8] <= Samples[7] ;
最后假设输入时10000000  得到的结果应该是跟滤波器的系数  现在的结果是7 24 17 32 46 52 46 32 17 7   就是多出来一个24  好像是加法器那块弄的不对  请高手指点!多谢!
xinu2009 发表于 2010-5-16 10:53:13 | 显示全部楼层
可惜,没做过滤波器!
不过我建议用modelsim仿真试试,看一看中间信号的变化过程,分析内部信号的流程,我想这个是解决问题的关键!
Sunlife 发表于 2015-5-19 14:56:13 | 显示全部楼层
可惜,没做过滤波器!
GMT+8, 2026-5-23 06:08 , Processed in 0.031920 second(s), 20 queries .
