查看: 2072|回复: 1
用Nios II创建多处理器
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-15 14:18:51 | 显示全部楼层 |阅读模式
用Nios II创建多处理器
今天利用Nios II创建了一个多处理器,不过没有成功,非常麻烦呀。编译时间太长了。可能是机器太烂。
这个是Nios II IDE中用到的C代码:
#include <stdio.h>
#include <string.h>
#include "sys/alt_alarm.h"
#include "system.h"
#include "nios2.h"
#include "altera_avalon_mutex.h"
#define MESSAGE_WAITING 1
#define NO_MESSAGE 0
#define LOCK_SUCCESS 0
#define LOCK_FAIL 1
#define MESSAGE_BUFFER_BASE MESSAGE_BUFFER_RAM_BASE
#define FIRST_LOCK 1 /* for testing only */
#define ERROR_OPENED_INVALID_MUTEX 1 /* for testing only */
#define ERROR_ALLOWED_ACCESS_WITHOUT_OWNING_MUTEX 2 /* for testing only */
#define ERROR_COULDNT_OPEN_MUTEX 3 /* for testing only */
#define MS_DELAY 1000
// Message buffer structure
typedef struct {
char flag;
char buf[100];
} message_buffer_struct;
int main()
// Pointer to our mutex device
alt_mutex_dev* mutex = NULL;
// Local variables
unsigned int id;
unsigned int value;
unsigned int count = 0;
unsigned int ticks_at_last_message;
char got_first_lock = 0; /* for testing only */
unsigned int error_code = 0; /* for testing only */
message_buffer_struct *message;
// Get our processor ID (add 1 so it matches the cpu name in SOPC Builder)
NIOS2_READ_CPUID(id);
id += 1;
// Value can be any non-zero value
value = 1;
// Initialize the message buffer location
message = (message_buffer_struct*)MESSAGE_BUFFER_BASE;
// We&#39;ll try to open the wrong mutex here and hope it&#39;s not successful.
mutex = altera_avalon_mutex_open("/dev/wrong_device_name"); /* for testing only */
if (mutex != NULL) /* for testing only */
  // Whoops, opening the invalid mutex was successful.
  error_code = ERROR_OPENED_INVALID_MUTEX; /* for testing only */
  goto error; /* for testing only */
// Okay, now we&#39;ll open the real mutex
// It&#39;s not actually a mutex to share the jtag_uart, but to share a message
// buffer which CPU1 is responsible for reading and printing to the jtag_uart.
mutex = altera_avalon_mutex_open(MESSAGE_BUFFER_MUTEX_NAME);
// We&#39;ll use the system clock to keep track of our delay time.
// Here we initialize delay tracking variable.
ticks_at_last_message = alt_nticks();
if (mutex)
  // If the mutex has never been locked, clear the message flag.
  // We are safe to use the non-blocking "trylock" function here
  // because if we dont get the mutex on the first shot, it means
  // someone else already has it and we clearly arent going to be
  // the first to release it anyway.
  if(altera_avalon_mutex_trylock(mutex, value) == LOCK_SUCCESS) /* for testing only */
   if (altera_avalon_mutex_first_lock(mutex) == FIRST_LOCK) /* for testing only */
    message->flag = NO_MESSAGE; /* for testing only */
    got_first_lock = 1; /* for testing only */
   altera_avalon_mutex_unlock(mutex); /* for testing only */
  while(1)
   // See if it&#39;s time to send a message yet
   if (alt_nticks() >= (ticks_at_last_message + ((alt_ticks_per_second() * (MS_DELAY)) / 1000)))
    // Try and aquire the mutex (non-blocking).
     // Just make sure we own the mutex
     if(altera_avalon_mutex_is_mine(mutex)) /* for testing only */
      // Check if the message buffer is empty
      if(message->flag == NO_MESSAGE)
       count++;
       // If we were the first to lock the mutex, say so in our first message.
       if (got_first_lock) /* for testing only */
        sprintf(message->buf, "FIRST LOCK - Message from CPU %d. Number sent: %d\n", id, count); /* for testing only */
        sprintf(message->buf, "Message from CPU %d. Number sent: %d\n", id, count);
       // Set the flag that a message has been put in the buffer.
       message->flag = MESSAGE_WAITING;
     else /* for testing only */
      error_code = ERROR_ALLOWED_ACCESS_WITHOUT_OWNING_MUTEX; /* for testing only */
     // Release the mutex
   // If we are CPU1, check the message buffer
   // and if there&#39;s a message, print it to stdout.
//   if(id == 1)
#ifdef JTAG_UART_NAME
    if(message->flag == MESSAGE_WAITING)
     // We dont really need to lock the mutex here since the if(id == 1) statement
     // assures we are the only CPU grabbing messages out of the buffer, but
     // we&#39;ll do it anyway to test the blocking lock routine.
     altera_avalon_mutex_lock(mutex, value); /* for testing only */
      printf("%s", message->buf);
     // Release the Mutex
#endif /* JTAG_UART_NAME */
  error_code = ERROR_COULDNT_OPEN_MUTEX; /* for testing only */
error: /* for testing only */
return(error_code); /* for testing only */
// return(0);
附件是用到的QII 文件,平台是DE2,其它的版子改一下就行了
zhiweiqiang33 发表于 2017-11-6 10:45:58 | 显示全部楼层
Xilinx MicroBlaze的使用方法[技术文档]
GMT+8, 2026-5-24 18:11 , Processed in 0.040356 second(s), 21 queries .
