查看: 1428|回复: 2
跪求高手指点
xiaqisong 发表于 2012-1-10 16:10:34 | 显示全部楼层 |阅读模式
-- Company:
-- Engineer:
-- Create Date:    16:09:01 01/04/2012
-- Design Name:
-- Module Name:    Uart_mysilf - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Uart_mysilf is
   port(  clk:in std_logic;
               rx :in std_logic;
--                         tx_flage :in std_logic;
                         rx_flage ut std_logic;
                         tx    : out std_logic
  --       clkout : out std_logic
end Uart_mysilf;
architecture Behavioral of Uart_mysilf is
signal cnt    : std_logic_vector(15 downto 0) :="0000000000000000";
signal cnt1    : std_logic_vector(3 downto 0) :="0000";
signal cnt2    : std_logic_vector(3 downto 0) :="0000";
signal tx_buffer    : std_logic_vector(7 downto 0) :="00000000";
signal rx_buffer    : std_logic_vector(7 downto 0) :="00000000";
signal bclk : std_logic :='0';
--signal rx_flage: std_logic:='0' ;
signal tx_flage : std_logic:='0' ;
signal send : std_logic:='0' ;
   process(clk)
              cnt<=cnt+"0000000000000001";
         if(cnt="00000000001010000101")then
             bclk<='0';
         elsif(cnt="000000000010100001010")then
             bclk<='1';
             cnt<="0000000000000000";
         end if;
   end process;
        process(bclk)
             if(bclk='1') then
                  if(rx='0')  then
                          cnt2<=cnt2+"0001";
                        end if;
                        --end if;
                        case cnt2 is
                        when "0001" =>
                                     rx_buffer(0)<=rx;
                                                         cnt2<=cnt2+"0001";
                        when "0010" =>
                                                rx_buffer(1)<=rx;
                      cnt2<=cnt2+"0001";
                        when "0011" =>
                                     rx_buffer(2)<=rx;
                                                        cnt2<=cnt2+"0001";
                        when "0100" =>
                                           rx_buffer(3)<=rx;
                                                         cnt2<=cnt2+"0001";
                        when "0101" =>
                                            rx_buffer(4)<=rx;
                                                         cnt2<=cnt2+"0001";
                        when "0110" =>
                                     rx_buffer(5)<=rx;
                                                         cnt2<=cnt2+"0001";
                        when "0111" =>
                                     rx_buffer(6)<=rx;
                                                        cnt2<=cnt2+"0001";
                        when "1000" =>
                                     rx_buffer(7)<=rx;
                                                         cnt2<=cnt2+"0001";
                        when "1001" =>
                          --           tx_buffer<=rx_buffer;
                                                         tx_flage<='1';
                                                         rx_flage<='1';
                   when others =>
                      -- cnt1<=cnt1;
         end case;
                        if(cnt2="1001") then
---                           tx_flage<='1';
                           cnt2<="0000";
                                end if;
                        end if;
   end process;
        process(bclk)
                  tx_buffer<="01011010";
             if(bclk='1') then
                  if(tx_flage='1') then
                            cnt1<=cnt1+"0001";
                                tx_flage<='0';
                           end if;
                        case cnt1 is
                        when "0001" =>
                                      tx<='0';
                                                          cnt1<=cnt1+"0001";
                        when "0010" =>
                                      tx<=tx_buffer(0);
                       cnt1<=cnt1+"0001";
                        when "0011" =>
                                      tx<=tx_buffer(1);
        cnt1<=cnt1+"0001";
                        when "0100" =>
                                      tx<=tx_buffer(2);
                                                         cnt1<=cnt1+"0001";
                        when "0101" =>
                                      tx<=tx_buffer(3);
                                                          cnt1<=cnt1+"0001";
                        when "0110" =>
                                      tx<=tx_buffer(4);
                                                          cnt1<=cnt1+"0001";
                        when "0111" =>
                                      tx<=tx_buffer(5);
                                                          cnt1<=cnt1+"0001";
                        when "1000" =>
                                      tx<=tx_buffer(6);
                                                          cnt1<=cnt1+"0001";
                        when "1001" =>
                                      tx<=tx_buffer(7);
                                                          cnt1<=cnt1+"0001";
                        when "1010" =>
                                      tx<='1';
                                                          cnt1<="0000";
                                        --                  tx_flage<='0';
                                                         -- cnt1<="0000";
                   when others =>
                      -- cnt1<=cnt1;
         end case;
                        end if;
   end process;
end Behavioral;
在编译的时候出现错误啊
ERROR:Xst:528 - Multi-source in Unit <Uart_mysilf> on signal <tx_flage>
Sources are:
   Output signal of LDE instance <tx_flage/0>
   Signal <tx_flage> in Unit <Uart_mysilf> is assigned to GND
CPU : 2.70 / 2.83 s | Elapsed : 3.00 / 3.00 s
跪求高手指点
 楼主| xiaqisong 发表于 2012-1-10 16:16:40 | 显示全部楼层
跪求高手帮我找找原因啊
 楼主| xiaqisong 发表于 2012-1-10 16:25:56 | 显示全部楼层
高手在哪啊
GMT+8, 2026-5-23 22:42 , Processed in 0.038597 second(s), 20 queries .
