查看: 3252|回复: 2
交通灯源码
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-18 12:54:22 | 显示全部楼层 |阅读模式
交通灯
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY TrafficLight IS
PORT (Clk        : IN STD_LOGIC;
    S,Reset      : IN STD_LOGIC;
    LED        : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
    Mg,My,Mr,Cg,Cy,Cr : OUT STD_LOGIC );
END TrafficLight ;
ARCHITECTURE rtl OF TrafficLight IS
TYPE TrafficState IS (mgcr, mycr, mrcg, mrcy);
SIGNAL State  : TrafficState ;
SIGNAL DataOut : STD_LOGIC_VECTOR(5 DOWNTO 0);
SIGNAL Count  : STD_LOGIC_VECTOR(5 DOWNTO 0);
SIGNAL SetCount : STD_LOGIC_VECTOR(5 DOWNTO 0);
SIGNAL Clrn   : STD_LOGIC ;
SIGNAL LEDB   : STD_LOGIC_VECTOR(7 DOWNTO 0);
BEGIN
Counter : PROCESS(clk)
BEGIN
  IF Reset = &#39;1&#39; OR (Clrn = &#39;1&#39; AND NOT(Count = "000000")) THEN Count <= "000000";
  ELSIF clk&#39;EVENT AND clk = &#39;1&#39; THEN
   IF NOT(Count = "111011" AND State = mgcr) THEN Count <= Count + 1;END IF;
  END IF;
END PROCESS Counter;
StateTransition : PROCESS(clk)
BEGIN
  IF Reset = &#39;1&#39; THEN State <= mgcr;Clrn <= &#39;0&#39;;
    CASE State IS
     WHEN mgcr => IF Count >= "111011" AND S = &#39;1&#39; THEN State <= mycr;Clrn <= &#39;1&#39;;
            ELSE Clrn <= &#39;0&#39;;
            END IF;
     WHEN mycr => IF Count >= "000011" THEN State <= mrcg;Clrn <= &#39;1&#39;;
            END IF;
     WHEN mrcg => IF Count >= "010011" OR S = &#39;0&#39; THEN State <= mrcy;Clrn <= &#39;1&#39;;
            END IF;
     WHEN mrcy => IF Count >= "000011" THEN State <= mgcr;Clrn <= &#39;1&#39;;
            END IF;
     WHEN OTHERS => NULL;
    END CASE;
  END IF;
END PROCESS StateTransition;
CountDown : PROCESS(CLK)
BEGIN
  IF LEDB > 59 THEN LED <= LEDB + 36;
  ELSIF LEDB > 49 THEN LED <= LEDB + 30;
  ELSIF LEDB > 39 THEN LED <= LEDB + 24;
  ELSIF LEDB > 29 THEN LED <= LEDB + 18;
  ELSIF LEDB > 19 THEN LED <= LEDB + 12;
  ELSIF LEDB > 9 THEN LED <= LEDB + 6;
  ELSE LED <= LEDB;
  END IF;
END PROCESS CountDown;
Output : BLOCK
BEGIN
  WITH State SELECT
   DataOut <= "100001" WHEN mgcr,
         "010001" WHEN mycr,
         "001100" WHEN mrcg,
         "001010" WHEN mrcy;
  WITH State SELECT
   SetCount <= "111100" WHEN mgcr,
         "000100" WHEN mycr,
         "010100" WHEN mrcg,
         "000100" WHEN mrcy;
  Mg <= DataOut(5);My <= DataOut(4);Mr <= DataOut(3);
  Cg <= DataOut(2);Cy <= DataOut(1);Cr <= DataOut(0);
  LEDB <= SetCount - ("00" & Count);
END BLOCK Output;
END ARCHITECTURE rtl;
lisuai 发表于 2012-2-26 22:40:22 | 显示全部楼层
神马东西啊,注释都没有还叫程序吗
fpga_feixiang 发表于 2022-3-20 17:04:40 | 显示全部楼层
6666666666666666666
GMT+8, 2026-5-24 05:51 , Processed in 0.031737 second(s), 21 queries .
