查看: 2553|回复: 2
跪求FPGA高手帮忙仿真
minfly1234 发表于 2010-5-19 02:41:54 | 显示全部楼层 |阅读模式
在下毕设遇到瓶颈,不知道用quartus软件,所以跪求各位高手帮忙仿真,最好能附带波形图跟注解。感激不尽,谢谢!
module dpll(reset,clk,signal_in,signal_out,syn);
parameter para_K=4;
parameter para_N=16;
input reset;
input clk;
input signal_in;
output signal_out;
output syn;
reg signal_out;
reg dpout;
reg delclk;
reg addclk;
reg add_del_clkout;
reg [7:0]up_down_cnt;
reg [2:0]cnt8;
reg [8:0]cnt_N;
reg syn;
reg dpout_delay;
reg [8:0]cnt_dpout_high;
reg [8:0]cnt_dpout_low;
/******phase detector*****/
always@(signal_in or signal_out)
    dpout<=signal_in^signal_out;
/******synchronization establish detector*****/
always@(posedge clk or negedge reset)
        if(!reset)    dpout_delay<='b0;
        else          dpout_delay<=dpout;
      if(!reset)
            cnt_dpout_high<='b0; cnt_dpout_low<='b0;
      else if(dpout)
                if(dpout_delay==0)  cnt_dpout_high<='b0;
                    if(cnt_dpout_high==8'b11111111)  cnt_dpout_high<='b0;
                    else  cnt_dpout_high<=cnt_dpout_high+1;
      else if(!dpout)
                 if(dpout_delay==1)  cnt_dpout_low<='b0;
                     if(cnt_dpout_low==8'b11111111)  cnt_dpout_low<='b0;
                     else  cnt_dpout_low<=cnt_dpout_low+1;
          if(!reset)  syn<='b0;
      else if((dpout&&!dpout_delay)||(!dpout&&dpout_delay))
           if(cnt_dpout_high[8:0]-cnt_dpout_low[8:0]<=4||cnt_dpout_low[8:0]-cnt_dpout_high[8:0]<=4)  syn<='b1;
           else  syn<='b0;
/****up down couter with mod=K****/
   if(!reset)
       delclk<='b0;
       addclk<='b0;
       up_down_cnt<='b00000000;
      if(!dpout)
        delclk<='b0;
        if(up_down_cnt==para_K-1)
            addclk<='b0;
           up_down_cnt<=up_down_cnt+1;
           addclk<='b0;
  addclk<='b0;
           if(up_down_cnt=='b0)
               up_down_cnt<=para_K-1;
               delclk<='b0;
             if(up_down_cnt==1)
                 delclk<='b1;
                 up_down_cnt<=up_down_cnt-1;
/******add and delete clk*****/
  if(!reset)
       cnt8<='b000;
      if(cnt8=='b111)
      cnt8<='b000;
    if(addclk&&!syn)
         cnt8<=cnt8+2;
       if(delclk&&!syn)
          cnt8<=cnt8;
          cnt8<=cnt8+1;
always@(cnt8 or reset)
if(!reset)
  add_del_clkout<='b0;
  add_del_clkout<=cnt8[2];
/******counter with mod=N******/
always@(posedge add_del_clkout or negedge reset)
  if(!reset)
    cnt_N<='b0000;
    signal_out<='b0;
     if(cnt_N==para_N-1)
         cnt_N<='b0000;
         signal_out<='b0;
   if(cnt_N==(para_N-1)/2)
       signal_out<='b1;
       cnt_N<=cnt_N+1;
      cnt_N<=cnt_N+1;
DPLL由  鉴相器、 模K加减计数器、脉冲加减电路、同步建立侦察电路、模N分频器构成.
整个系统的中心频率(即signal_in和signal_out的码速率的2倍)为clk/8/N.  模K加减计数器的K值决定DPLL的精度和同步建立时间,K越大,则同步建立时间长,同步精度高.反之则短,低.
xpz35 发表于 2010-6-21 18:04:15 | 显示全部楼层
怎么都看不到回复呢
IPO 发表于 2010-6-21 18:22:14 | 显示全部楼层
没有测试文件.
GMT+8, 2026-5-24 07:57 , Processed in 0.032269 second(s), 21 queries .
