查看: 1632|回复: 2
大师们求助啊!在线等啊大师!
我额 发表于 2012-2-14 14:11:10 | 显示全部楼层 |阅读模式
以下的流水灯程序在实际过程中8盏灯始终是全亮的,请问大师哪里出错了?
library ieee;
use ieee.std_logic_1164.all;
--use ieee.std_logic_signed.all;
--use ieee.std_logic_arith.all;
entity lxd is
port (
      --reset: in std_logic;--系统复位信号
          clk:in std_logic; --1hz时钟信号
         a1,a2,a3,a4,a5,a6,a7,a8: out std_logic);
end lxd;
architecture bhv of lxd is
signal q: std_logic ;
signal q1: std_logic_vector(3 downto 0);
signal c: std_logic_vector(7 downto 0);
signal clk1: std_logic;
process(clk)  --对系统时钟3000000分频;
   variable cnt:integer range 0 to 30000000 ;
   variable q: std_logic;
if clk'event and clk='1'then
  if cnt =29999999 then
  cnt:=0 ; q:='1';
    cnt:=cnt+1; q:='0';
  end if;
end  if;
clk1<=q;
end process;
process(clk)   --------控制灯显示,q1对时钟的上升沿计数
  if q1 ="1111" then q1<="0000";
  else q1<=q1+1;
end if;
end if;
end process;
process(q1)
case q1 is
when "0000" =>c<="01111111";
when "0001" =>c<="10111111";
when "0010" =>c<="11011111";
when "0011" =>c<="11101111";
when "0100" =>c<="11110111";
when "0101" =>c<="11111011";
when "0110" =>c<="11111101";
when "0111" =>c<="11111110";
when "1000" =>c<="11111110";
when "1001" =>c<="11111101";
when "1010" =>c<="11111011";
when "1011" =>c<="11110111";
when "1100" =>c<="11101111";
when "1101" =>c<="11011111";
when "1110" =>c<="10111111";
when "1111" =>c<="01111111";
when others =>c<="11111111";
end case;
a1<=c(0);a2<=c(1);a3<=c(2);a4<=c(3);a5<=c(4);a6<=c(5);a7<=c(6);a8<=c(7);
end process;
end bhv;
最是那低头温柔 发表于 2012-3-20 18:10:01 | 显示全部楼层
if(clk1='1')then
  else q1<=q1+1;
end if;
end if;
end if;
end process;
我觉得你的本意是调用分频中的CLK1,然后在控制LED的闪烁,故我给你的这段程序中加了CLK1的调用。30_000_000这个分频数大约对应的系统时钟为10~100M。不知你的系统时钟是否在这个范围内。
Sunlife 发表于 2015-4-9 10:58:45 | 显示全部楼层
GMT+8, 2026-5-23 12:11 , Processed in 0.031883 second(s), 21 queries .
