查看: 1801|回复: 1
求助LAB-wide clock 怎么理解?
qingmingjun 发表于 2012-2-23 15:41:51 | 显示全部楼层 |阅读模式
各位:
         我想请问一下LAB-wide clock怎么理解??芯片手册上的原话如下:
If the LAB uses both the rising and falling edges of a clock, it
also uses two LAB-wide clock signals. De-asserting the clock enable signal turns off
the corresponding LAB-wide clock.
 楼主| qingmingjun 发表于 2012-2-23 20:34:33 | 显示全部楼层
回复 1# qingmingjun
    各位大神,有木有对这个了解的??
GMT+8, 2026-5-23 19:30 , Processed in 0.059045 second(s), 23 queries .
