查看: 5631|回复: 7
基于分布式算法的FIR的VERILOG程序?
vvt 发表于 2010-5-25 11:15:06 | 显示全部楼层 |阅读模式
I2C 发表于 2010-5-25 11:15:50 | 显示全部楼层
module FIR_Gaussian_Lowpass(Data_out,Data_in,clock,reset,test,result9);
//8阶高斯低通FIR
parameter order = 8;
parameter word_size_in = 8;
parameter word_size_out = 2*word_size_in + 2;
parameter b0 = 8'd7;
parameter b1 = 8'd17;
parameter b2 = 8'd32;
parameter b3 = 8'd46;
parameter b4 = 8'd52;
parameter b5 = 8'd46;
parameter b6 = 8'd32;
parameter b7 = 8'd17;
parameter b8 = 8'd7;
parameter H = 1'b1,L = 1'b0;
output        [word_size_out -1 : 0]         Data_out;
input         [word_size_in -1 : 0]         Data_in;
input                                                         clock,reset;
reg         [word_size_in -1 : 0]        Samples[1rder];
output         [63:0] test;
output [15:0] result9;
integer k;
//multip mult1(.datain1(b0),.datain2(Data_in),.clock(clock),.result(Data_out1));
/*assign data_out        =        b0*Data_in
                                        +b1*Samples[1]
                                        +b2*Samples[2]
                                        +b3*Samples[3]
                                        +b4*Samples[4]
                                        +b5*Samples[5]
                                        +b6*Samples[6]
                                        +b7*Samples[7]
                                        +b8*Samples[8];*/
/*assign data_out        =        result0
                                        +result1
                                        +result2
                                        +result3
                                        +result4
                                        +result5
                                        +result6
                                        +result7
                                        +result8;*/
adder16X1 (
                        data0x,data10x,
                        data11x,data12x,
                        data13x,data14x,
                        data15x,data1x,
                        data2x,data3x,
                        data4x,data5x,
                        data6x,data7x,
                        data8x,data9x,
                        result
adder add1 (.data0x(result0),.data1x(result1),
                .data2x(result2),.data3x(result3),
                .data4x(result4),.data5x(result5),
                .data6x(result6),.data7x(result7),
                .result(result9));
adder add2 (.data0x(result8),.data1x(result9),
                .data2x(8'h00),.data3x(8'h00),
                .data4x(8'h00),.data5x(8'h00),
                .data6x(8'h00),.data7x(8'h00),
                .result(result10));
assign test = {Samples[1],Samples[2],Samples[3],Samples[4],
                                Samples[5],Samples[6],Samples[7],Samples[8]};
wire [7:0]        result0;
wire [7:0]        result1;
wire [7:0]        result2;
wire [7:0]        result3;
wire [7:0]        result4;
wire [7:0]        result5;
wire [7:0]        result6;
wire [7:0]        result7;
wire [7:0]        result8;
wire [15:0]        result9;
wire [15:0]        result10;
assign data_out = result9;
multiplex mult1(.dataa(b0),.datab(Data_in),.result(result0));
multiplex mult2(.dataa(b1),.datab(Samples[1]),.result(result1));
multiplex mult3(.dataa(b2),.datab(Samples[2]),.result(result2));
multiplex mult4(.dataa(b3),.datab(Samples[3]),.result(result3));
multiplex mult5(.dataa(b4),.datab(Samples[4]),.result(result4));
multiplex mult6(.dataa(b5),.datab(Samples[5]),.result(result5));
multiplex mult7(.dataa(b6),.datab(Samples[6]),.result(result6));
multiplex mult8(.dataa(b7),.datab(Samples[7]),.result(result7));
multiplex mult9(.dataa(b8),.datab(Samples[8]),.result(result8));
always @(posedge clock)
        if(reset == H)
                        /*for(k=1;k<=order;k=k+1)
                                Samples[k] <= 0;*/
                        Samples[1] <= 0;
                        Samples[2] <= 0;
                        Samples[3] <= 0;
                        Samples[4] <= 0;
                        Samples[5] <= 0;
                        Samples[6] <= 0;
                        Samples[7] <= 0;
                        Samples[8] <= 0;
                        Samples[1] <= Data_in;
                        /*for(k=2;k<=order;k=k+1)
                                Samples[k] <= Samples[k-1];*/
                        Samples[2] <= Samples[1] ;
                        Samples[3] <= Samples[2] ;
                        Samples[4] <= Samples[3] ;
                        Samples[5] <= Samples[4] ;
                        Samples[6] <= Samples[5] ;
                        Samples[7] <= Samples[6] ;
                        Samples[8] <= Samples[7] ;
白开水的噩梦 发表于 2011-12-31 12:59:52 | 显示全部楼层
好厉害 哈 我哈哈
fhelei 发表于 2012-4-5 18:59:13 | 显示全部楼层
求分布式算法原理。。。谢谢
fhelei 发表于 2012-4-5 18:59:19 | 显示全部楼层
求分布式算法原理。。。谢谢
fhelei 发表于 2012-4-5 19:03:07 | 显示全部楼层
求分布式算法原理。。。谢谢
zxopenljx 发表于 2021-2-21 17:35:08 | 显示全部楼层
zxopenhl 发表于 2021-3-4 17:33:40 | 显示全部楼层
GMT+8, 2026-5-22 12:03 , Processed in 0.034791 second(s), 20 queries .
