查看: 1874|回复: 1
哪位做过基于FPGA函数信号发生器(频率和相位可调,VHDL语言编写的)的前辈
ddd 发表于 2012-3-12 12:34:52 | 显示全部楼层 |阅读模式
哪位做过基于FPGA函数信号发生器(频率和相位可调,VHDL语言编写的)的前辈。能不能借鉴下啊,我是刚学FPGA方面,不太懂
ChenDongKui 发表于 2012-4-2 21:06:02 | 显示全部楼层
这个使用DDS技术很容易做到。我用VERILOG写过这个东西,如有需要可与我联系,下面给你一个参考代码。
sine.v文件
module sine(
        input  clk,
        input  [7:0]phase,
        input  nRst,
        output [15:0]data
reg [7:0] addr;
always@(posedge clk or negedge nRst)begin
  if(!nRst)begin
        addr <= phase;
  else begin
        addr <= addr +1'b1;
sineData GenerateSineDataByAddr(
        .clock(clk),
        .address(addr),
        .q(data)
//SineData.v文件
// megafunction wizard: %ROM: 1-PORT%
// GENERATION: STANDARD
// VERSION: WM1.0
// MODULE: altsyncram
// File Name: sineData.v
// Megafunction Name(s):
//                         altsyncram
// Simulation Library Files(s):
//                         altera_mf
// THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
// 9.0 Build 132 02/25/2009 SJ Full Version
//Copyright (C) 1991-2009 Altera Corporation
//Your use of Altera Corporation's design tools, logic functions
//and other software and tools, and its AMPP partner logic
//functions, and any output files from any of the foregoing
//(including device programming or simulation files), and any
//associated documentation or information are expressly subject
//to the terms and conditions of the Altera Program License
//Subscription Agreement, Altera MegaCore Function License
//Agreement, or other applicable license agreement, including,
//without limitation, that your use is for the sole purpose of
//programming logic devices manufactured by Altera and sold by
//Altera or its authorized distributors.  Please refer to the
//applicable agreement for further details.
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module sineData (
        address,
        clock,
        q);
        input        [7:0]  address;
        input          clock;
        output        [11:0]  q;
        wire [11:0] sub_wire0;
        wire [11:0] q = sub_wire0[11:0];
        altsyncram        altsyncram_component (
                                .clock0 (clock),
                                .address_a (address),
                                .q_a (sub_wire0),
                                .aclr0 (1'b0),
                                .aclr1 (1'b0),
                                .address_b (1'b1),
                                .addressstall_a (1'b0),
                                .addressstall_b (1'b0),
                                .byteena_a (1'b1),
                                .byteena_b (1'b1),
                                .clock1 (1'b1),
                                .clocken0 (1'b1),
                                .clocken1 (1'b1),
                                .clocken2 (1'b1),
                                .clocken3 (1'b1),
                                .data_a ({12{1'b1}}),
                                .data_b (1'b1),
                                .eccstatus (),
                                .q_b (),
                                .rden_a (1'b1),
                                .rden_b (1'b1),
                                .wren_a (1'b0),
                                .wren_b (1'b0));
        defparam
                altsyncram_component.address_aclr_a = "NONE",
                altsyncram_component.clock_enable_input_a = "BYPASS",
                altsyncram_component.clock_enable_output_a = "BYPASS",
                altsyncram_component.init_file = "sine.mif",
                altsyncram_component.intended_device_family = "Cyclone III",
                altsyncram_component.lpm_hint = "ENABLE_RUNTIME_MOD=NO",
                altsyncram_component.lpm_type = "altsyncram",
                altsyncram_component.numwords_a = 256,
                altsyncram_component.operation_mode = "ROM",
                altsyncram_component.outdata_aclr_a = "NONE",
                altsyncram_component.outdata_reg_a = "CLOCK0",
                altsyncram_component.widthad_a = 8,
                altsyncram_component.width_a = 12,
                altsyncram_component.width_byteena_a = 1;
// CNX file retrieval info
// Retrieval info: PRIVATE: ADDRESSSTALL_A NUMERIC "0"
// Retrieval info: PRIVATE: AclrAddr NUMERIC "0"
// Retrieval info: PRIVATE: AclrByte NUMERIC "0"
// Retrieval info: PRIVATE: AclrOutput NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_ENABLE NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_SIZE NUMERIC "8"
// Retrieval info: PRIVATE: BlankMemory NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_A NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_A NUMERIC "0"
// Retrieval info: PRIVATE: Clken NUMERIC "0"
// Retrieval info: PRIVATE: IMPLEMENT_IN_LES NUMERIC "0"
// Retrieval info: PRIVATE: INIT_FILE_LAYOUT STRING "PORT_A"
// Retrieval info: PRIVATE: INIT_TO_SIM_X NUMERIC "0"
// Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone III"
// Retrieval info: PRIVATE: JTAG_ENABLED NUMERIC "0"
// Retrieval info: PRIVATE: JTAG_ID STRING "NONE"
// Retrieval info: PRIVATE: MAXIMUM_DEPTH NUMERIC "0"
// Retrieval info: PRIVATE: MIFfilename STRING "sine.mif"
// Retrieval info: PRIVATE: NUMWORDS_A NUMERIC "256"
// Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0"
// Retrieval info: PRIVATE: RegAddr NUMERIC "1"
// Retrieval info: PRIVATE: RegOutput NUMERIC "1"
// Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
// Retrieval info: PRIVATE: SingleClock NUMERIC "1"
// Retrieval info: PRIVATE: UseDQRAM NUMERIC "0"
// Retrieval info: PRIVATE: WidthAddr NUMERIC "8"
// Retrieval info: PRIVATE: WidthData NUMERIC "12"
// Retrieval info: PRIVATE: rden NUMERIC "0"
// Retrieval info: CONSTANT: ADDRESS_ACLR_A STRING "NONE"
// Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_A STRING "BYPASS"
// Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_A STRING "BYPASS"
// Retrieval info: CONSTANT: INIT_FILE STRING "sine.mif"
// Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone III"
// Retrieval info: CONSTANT: LPM_HINT STRING "ENABLE_RUNTIME_MOD=NO"
// Retrieval info: CONSTANT: LPM_TYPE STRING "altsyncram"
// Retrieval info: CONSTANT: NUMWORDS_A NUMERIC "256"
// Retrieval info: CONSTANT: OPERATION_MODE STRING "ROM"
// Retrieval info: CONSTANT: OUTDATA_ACLR_A STRING "NONE"
// Retrieval info: CONSTANT: OUTDATA_REG_A STRING "CLOCK0"
// Retrieval info: CONSTANT: WIDTHAD_A NUMERIC "8"
// Retrieval info: CONSTANT: WIDTH_A NUMERIC "12"
// Retrieval info: CONSTANT: WIDTH_BYTEENA_A NUMERIC "1"
// Retrieval info: USED_PORT: address 0 0 8 0 INPUT NODEFVAL address[7..0]
// Retrieval info: USED_PORT: clock 0 0 0 0 INPUT NODEFVAL clock
// Retrieval info: USED_PORT: q 0 0 12 0 OUTPUT NODEFVAL q[11..0]
// Retrieval info: CONNECT: @address_a 0 0 8 0 address 0 0 8 0
// Retrieval info: CONNECT: q 0 0 12 0 @q_a 0 0 12 0
// Retrieval info: CONNECT: @clock0 0 0 0 0 clock 0 0 0 0
// Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData.v TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData.inc FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData.cmp FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData.bsf TRUE FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData_inst.v FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData_bb.v TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData_waveforms.html TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL sineData_wave*.jpg FALSE
// Retrieval info: LIB_FILE: altera_mf
//sine.mif文件
DEPTH = 256;
WIDTH = 12;
ADDRESS_RADIX = HEX;
DATA_RADIX = DEC;
CONTENT
        BEGIN
0000 :  2048;
0001 :  2098;
0002 :  2148;
0003 :  2198;
0004 :  2248;
0005 :  2298;
0006 :  2348;
0007 :  2398;
0008 :  2447;
0009 :  2496;
000A :  2545;
000B :  2594;
000C :  2642;
000D :  2690;
000E :  2737;
000F :  2784;
0010 :  2831;
0011 :  2877;
0012 :  2923;
0013 :  2968;
0014 :  3013;
0015 :  3057;
0016 :  3100;
0017 :  3143;
0018 :  3185;
0019 :  3226;
001A :  3267;
001B :  3307;
001C :  3346;
001D :  3385;
001E :  3423;
001F :  3459;
0020 :  3495;
0021 :  3530;
0022 :  3565;
0023 :  3598;
0024 :  3630;
0025 :  3662;
0026 :  3692;
0027 :  3722;
0028 :  3750;
0029 :  3777;
002A :  3804;
002B :  3829;
002C :  3853;
002D :  3876;
002E :  3898;
002F :  3919;
0030 :  3939;
0031 :  3958;
0032 :  3975;
0033 :  3992;
0034 :  4007;
0035 :  4021;
0036 :  4034;
0037 :  4045;
0038 :  4056;
0039 :  4065;
003A :  4073;
003B :  4080;
003C :  4085;
003D :  4089;
003E :  4093;
003F :  4094;
0040 :  4095;
0041 :  4094;
0042 :  4093;
0043 :  4089;
0044 :  4085;
0045 :  4080;
0046 :  4073;
0047 :  4065;
0048 :  4056;
0049 :  4045;
004A :  4034;
004B :  4021;
004C :  4007;
004D :  3992;
004E :  3975;
004F :  3958;
0050 :  3939;
0051 :  3919;
0052 :  3898;
0053 :  3876;
0054 :  3853;
0055 :  3829;
0056 :  3804;
0057 :  3777;
0058 :  3750;
0059 :  3722;
005A :  3692;
005B :  3662;
005C :  3630;
005D :  3598;
005E :  3565;
005F :  3530;
0060 :  3495;
0061 :  3459;
0062 :  3423;
0063 :  3385;
0064 :  3346;
0065 :  3307;
0066 :  3267;
0067 :  3226;
0068 :  3185;
0069 :  3143;
006A :  3100;
006B :  3057;
006C :  3013;
006D :  2968;
006E :  2923;
006F :  2877;
0070 :  2831;
0071 :  2784;
0072 :  2737;
0073 :  2690;
0074 :  2642;
0075 :  2594;
0076 :  2545;
0077 :  2496;
0078 :  2447;
0079 :  2398;
007A :  2348;
007B :  2298;
007C :  2248;
007D :  2198;
007E :  2148;
007F :  2098;
0080 :  2047;
0081 :  1997;
0082 :  1947;
0083 :  1897;
0084 :  1847;
0085 :  1797;
0086 :  1747;
0087 :  1697;
0088 :  1648;
0089 :  1599;
008A :  1550;
008B :  1501;
008C :  1453;
008D :  1405;
008E :  1358;
008F :  1311;
0090 :  1264;
0091 :  1218;
0092 :  1172;
0093 :  1127;
0094 :  1082;
0095 :  1038;
0096 :   995;
0097 :   952;
0098 :   910;
0099 :   869;
009A :   828;
009B :   788;
009C :   749;
009D :   710;
009E :   672;
009F :   636;
00A0 :   600;
00A1 :   565;
00A2 :   530;
00A3 :   497;
00A4 :   465;
00A5 :   433;
00A6 :   403;
00A7 :   373;
00A8 :   345;
00A9 :   318;
00AA :   291;
00AB :   266;
00AC :   242;
00AD :   219;
00AE :   197;
00AF :   176;
00B0 :   156;
00B1 :   137;
00B2 :   120;
00B3 :   103;
00B4 :    88;
00B5 :    74;
00B6 :    61;
00B7 :    50;
00B8 :    39;
00B9 :    30;
00BA :    22;
00BB :    15;
00BC :    10;
00BD :     6;
00BE :     2;
00BF :     1;
00C0 :     0;
00C1 :     1;
00C2 :     2;
00C3 :     6;
00C4 :    10;
00C5 :    15;
00C6 :    22;
00C7 :    30;
00C8 :    39;
00C9 :    50;
00CA :    61;
00CB :    74;
00CC :    88;
00CD :   103;
00CE :   120;
00CF :   137;
00D0 :   156;
00D1 :   176;
00D2 :   197;
00D3 :   219;
00D4 :   242;
00D5 :   266;
00D6 :   291;
00D7 :   318;
00D8 :   345;
00D9 :   373;
00DA :   403;
00DB :   433;
00DC :   465;
00DD :   497;
00DE :   530;
00DF :   565;
00E0 :   600;
00E1 :   636;
00E2 :   672;
00E3 :   710;
00E4 :   749;
00E5 :   788;
00E6 :   828;
00E7 :   869;
00E8 :   910;
00E9 :   952;
00EA :   995;
00EB :  1038;
00EC :  1082;
00ED :  1127;
00EE :  1172;
00EF :  1218;
00F0 :  1264;
00F1 :  1311;
00F2 :  1358;
00F3 :  1405;
00F4 :  1453;
00F5 :  1501;
00F6 :  1550;
00F7 :  1599;
00F8 :  1648;
00F9 :  1697;
00FA :  1747;
00FB :  1797;
00FC :  1847;
00FD :  1897;
00FE :  1947;
00FF :  1997;
END ;
GMT+8, 2026-5-23 20:01 , Processed in 0.032104 second(s), 20 queries .
