查看: 4000|回复: 4
模块调用问题。
开心果 发表于 2012-4-3 14:51:05 | 显示全部楼层 |阅读模式
我是刚学的verilog,写了一个秒表程序,但是一直编译不过去,哪位大侠帮我看看啊!!!
module nixie_light(clk_n,wei,dat_n,cs_n,digit_n);
input clk_n;
input [3:0] dat_n;
input [2:0] wei;
output digit_n,cs_n;
parameter
    MSK_0       = 8'h40,       // '0'
    MSK_1       = 8'h79,       // '1'
    MSK_2       = 8'h24,       // '2'
    MSK_3       = 8'h30,       // '3'
    MSK_4       = 8'h19,       // '4'
    MSK_5       = 8'h12,       // '5'
    MSK_6       = 8'h02,       // '6'
    MSK_7       = 8'h78,       // '7'
    MSK_8       = 8'h00,       // '8'
    MSK_9       = 8'h10;       // '9'
reg    [16:0]   cnt2;
reg    [3:0]    submsk;
reg    [7:0]    cs_n;
reg    [7:0]    digit_n;
always @(posedge clk_n)
     cnt2 <= cnt2 + 1'b1;
     if (cnt2 == 17'd0)
                        cs_n<=8'hf0;
                        submsk<=dat_n;
always @(submsk)
case (submsk)
    4'h0:       digit_n <= MSK_0;
    4'h1:       digit_n <= MSK_1;
    4'h2:       digit_n <= MSK_2;
    4'h3:       digit_n <= MSK_3;
    4'h4:       digit_n <= MSK_4;
    4'h5:       digit_n <= MSK_5;
    4'h6:       digit_n <= MSK_6;
    4'h7:       digit_n <= MSK_7;
    4'h8:       digit_n <= MSK_8;
    4'h9:       digit_n <= MSK_9;
    default:    digit_n <= MSK_0;
endcase
always @(wei)
case (wei)
    3'd0:       cs_n <= 7'hfe;
    3'd1:       cs_n <= 7'hfd;
    3'd2:       cs_n <= 7'hfb;
    3'd3:       cs_n <= 7'hf7;
    3'd4:       cs_n <= 7'hef;
    3'd5:       cs_n <= 7'hdf;
    3'd6:       cs_n <= 7'hbf;
    3'd7:       cs_n <= 7'h7f;
    default:    cs_n <= 7'hfe;
endcase
module timepiece(clk,cs,digit_o);
input clk;
output [7:0]cs;
output [7:0]digit_o;
reg [27:0]count;
reg time_clk;
reg [5:0]date;
always @(posedge clk)
                if(count==28'h17D7840)
                                count<=1'b0;
                                time_clk<=~time_clk;
                else count<=count+1'b1;
reg [2:0]minute_s;
reg [3:0]minute_g;
//reg [1:0]hour_s;
//reg [3:0]hour_g;
always @(posedge time_clk)
                                if(minute_g==9)
                                        minute_g<=0;
                                        if(minute_s<=5)
                                                minute_s<=0;
                                                minute_s<=minute_s+1;
                                        minute_g<=minute_g+1;
reg    [3:0]    submsk;
reg    [7:0]    cs;
reg    [7:0]    digit_o;
nixie_light(clk,1,minute_s,cs,digit_o);
nixie_light(clk,2,minute_g,cs,digit_o);
编译后的错误是
Error (10663): Verilog HDL Port Connection error at timepiece.v(96): output or inout port "cs_n" must be connected to a structural net expression
Error (10663): Verilog HDL Port Connection error at timepiece.v(96): output or inout port "digit_n" must be connected to a structural net expression
zombes 发表于 2012-4-3 18:46:41 | 显示全部楼层
reg    [7:0]    digit_n;
output digit_n;
先改成一致看行不行
tao2000 发表于 2012-4-4 10:46:50 | 显示全部楼层
reg    [7:0]    cs;
reg    [7:0]    digit_o;
这两句去掉
还有就是调用nixie_light模块没有给出调用名称
 楼主| 开心果 发表于 2012-4-4 20:34:34 | 显示全部楼层
回复 2# zombes
谢谢哦!!我慢慢改程序改对了!!这个程序里又太多错误了,最大的错误就是
不能多次对cs,digit_o赋值,我用状态机解决了这个问题,
 楼主| 开心果 发表于 2012-4-4 20:36:49 | 显示全部楼层
回复 3# tao2000
    呵呵呵  谢谢啊!!问题已经解决了!!问题太多,而且调用模块可以省略你说的调用名字的
GMT+8, 2026-5-23 20:33 , Processed in 0.043884 second(s), 23 queries .
