查看: 4717|回复: 3
verilog求模运算求解
yi215415 发表于 2012-4-18 19:19:44 | 显示全部楼层 |阅读模式
`timescale 1ns / 1ps
module seg(
    input clk,
    input sw,
    output  [7:0] qg,qs,qb,qq
reg [31:0] count;
reg [13:0] cnt;
reg        [3:0] g,s,b,q;
always@(posedge clk,negedge sw)
                if(!sw)
                                count <= 0;
                                cnt <= 0;
                else if(count == 50_000_000)   //delay 1s
                                count <= 0;
                                cnt <= cnt + 1;
                                g <=        cnt % 10;
                                s <=        cnt / 10 % 10;
                                b <=        cnt / 100 % 10;
                                q <=        cnt / 1000 % 10;
                else if(cnt == 9999)
                        cnt <= 0;
                        count <= count + 1;
//assign                g =        cnt % 10;
//assign                s =        cnt / 10 % 10;
//assign                b =        cnt / 100 % 10;
//assign                q =        cnt / 1000 % 10;
assign qg = seg(g);
assign qs = seg(s);
assign qb = seg(b);
assign qq = seg(q);
function  [7:0] seg;
input [3:0] temp;
        case(temp)
                4'd0        :        seg = 8'h3f;
                4'd1        :        seg = 8'h06;
                4'd2        :        seg = 8'h5b;
                4'd3        :        seg = 8'h4f;
                4'd4        :        seg = 8'h66;
                4'd5        :        seg = 8'h6d;
                4'd6        :        seg = 8'h7d;
                4'd7        :        seg = 8'h07;
                4'd8        :        seg = 8'h7f;
                4'd9        :        seg = 8'h6f;
        default        :        seg = 8'hxx;
        endcase
endfunction
这是我写的代码是一个计算0-9999的计数器,在用数码管显示的,现在这个代码有错误通不过检测
错误提示:
ERROR:Xst:867 - "seg.v" line 23: Operator % is only supported when the second operand is a power of 2.
在线等高手求解!谢谢!
 楼主| yi215415 发表于 2012-4-19 09:09:12 | 显示全部楼层
我用的是ISE,里面不能直接进行这样的运算,怎么样才能得到一个数除以另一个数的余数和商呢?
 楼主| yi215415 发表于 2012-4-19 09:09:17 | 显示全部楼层
 楼主| yi215415 发表于 2012-4-19 09:09:18 | 显示全部楼层
GMT+8, 2026-5-23 19:30 , Processed in 0.042353 second(s), 20 queries .
