查看: 1630|回复: 3
请问高手verilog的$fwrite怎么使用呀
ccc 发表于 2012-5-7 10:39:19 | 显示全部楼层 |阅读模式
 楼主| ccc 发表于 2012-5-7 10:39:27 | 显示全部楼层
将信号值从modelsim中输出到文本文件中
 楼主| ccc 发表于 2012-5-7 10:39:29 | 显示全部楼层
yoyo_note 发表于 2012-5-16 23:16:03 | 显示全部楼层
EXAMPLE
// file open close example with $fwrite
module writetask();
    integer mcd1,mcd2,number,pointer;
    initial
        $display("value of mcd1 before opening the file %b " , mcd1);
        $display("value of mcd2 before opening the file %b " , mcd2);
        mcd1 = $fopen("xyz.txt");
        mcd2 = $fopen("pqr.txt");
        $display("value of mcd1 after opening the file %b " , mcd1);
        $display("value of mcd2 after opening the file %b " , mcd2);
        repeat(7)
             pointer = $random;
             number = $random % 10;
             $fwriteo(mcd1, " Number is ", number);
             $fwriteh(mcd2, " Pointer is ", pointer);
        $fclose(mcd1);
        $fclose(mcd2);
from http://www.testbench.in/TB_26_FILE_HANDLING.html
GMT+8, 2026-5-23 18:04 , Processed in 0.034858 second(s), 23 queries .
