查看: 1923|回复: 2
7段译码器Verilog代码
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-28 10:45:56 | 显示全部楼层 |阅读模式
7段译码器
// DESCRIPTION  :  BIN to seven segments converter
//          segment encoding
//            a
//          f |  | b
//           +---+ <- g
//          e |  | c
//            d
//         Enable (EN) active        : high
//         Outputs (data_out) active     : low
module bin27seg (data_in ,EN ,data_out );
  input [3:0] data_in ;
  input EN ;
  output [6:0] data_out ;
  reg [6:0] data_out ;
  always @(data_in or EN )
    data_out = 7&#39;b1111111;
    if (EN == 1)
      case (data_in )
        4&#39;b0000: data_out = 7&#39;b1000000; // 0
        4&#39;b0001: data_out = 7&#39;b1111001; // 1
        4&#39;b0010: data_out = 7&#39;b0100100; // 2
        4&#39;b0011: data_out = 7&#39;b0110000; // 3
        4&#39;b0100: data_out = 7&#39;b0011001; // 4
        4&#39;b0101: data_out = 7&#39;b0010010; // 5
        4&#39;b0110: data_out = 7&#39;b0000011; // 6
        4&#39;b0111: data_out = 7&#39;b1111000; // 7
        4&#39;b1000: data_out = 7&#39;b0000000; // 8
        4&#39;b1001: data_out = 7&#39;b0011000; // 9
        4&#39;b1010: data_out = 7&#39;b0001000; // A
        4&#39;b1011: data_out = 7&#39;b0000011; // b
        4&#39;b1100: data_out = 7&#39;b0100111; // c
        4&#39;b1101: data_out = 7&#39;b0100001; // d
        4&#39;b1110: data_out = 7&#39;b0000110; // E
        4&#39;b1111: data_out = 7&#39;b0001110; // F
        default: data_out = 7&#39;b1111111;
      endcase
weibode01 发表于 2010-11-9 11:10:47 | 显示全部楼层
好程序。。。。
sunmaster 发表于 2011-4-12 19:10:21 | 显示全部楼层
没看出来,一般般
GMT+8, 2026-5-24 01:58 , Processed in 0.032890 second(s), 21 queries .
