查看: 2321|回复: 2
移位寄存器Verilog代码
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-28 10:47:00 | 显示全部楼层 |阅读模式
移位寄存器
// DESCRIPTION  : Shift register
//         Type : univ
//         Width : 4
//         Shift direction: right/left (right active high)
//         CLK active : high
//         CLR active : high
//         CLR type : synchronous
//         SET active : high
//         SET type : synchronous
//         LOAD active : high
//         CE active : high
//         SERIAL input : SI
module shft_reg (CLR , SET , DIR , CE , LOAD , DATA , SI , data_out , CLK );
input CLR , SET , CE , LOAD , DIR , SI , CLK ;
input [3:0] DATA ;
output [3:0] data_out ;
reg [3:0] TEMP;
  always @(posedge CLK )
    if (CE == 1'b1)
      if (CLR == 1'b1)
        TEMP = {4{1'b0}};
      else if (SET == 1'b1)
        TEMP = {4{1'b1}};
      else if (LOAD == 1'b1)
        TEMP = DATA ;
      else if (DIR == 1'b1)
        TEMP = {SI , TEMP [3:1]};
        TEMP = {TEMP [2:0], SI };
  assign data_out = TEMP;
weibode01 发表于 2010-11-9 11:11:53 | 显示全部楼层
这些都是我最近实验的内容
伍金霄 发表于 2016-5-10 11:51:37 | 显示全部楼层
有人做过红外测距没?
GMT+8, 2026-5-23 02:55 , Processed in 0.032191 second(s), 21 queries .
