查看: 2206|回复: 1
状态机举例-Verilog HDL 代码
老怪甲 该用户已被删除
老怪甲 发表于 2010-5-28 10:48:18 | 显示全部楼层 |阅读模式
状态机举例-Verilog HDL 程序举例
一个同步状态机
Verilog HDL: Synchronous State Machine
This is a Verilog example that shows the implementation of a state machine.
The first CASE statement defines the outputs that are dependent on the value of the state machine variable state.
The second CASE statement defines the transitions of state machine and the conditions that control them.
statem.v
module statem(clk, in, reset, out);
input clk, in, reset;
output [3:0] out;
reg [3:0] out;
reg [1:0] state;
parameter zero=0, one=1, two=2, three=3;
always @(state)
     case (state)
        zero:
          out = 4'b0000;
        one:
          out = 4'b0001;
        two:
          out = 4'b0010;
        three:
          out = 4'b0100;
        default:
          out = 4'b0000;
     endcase
always @(posedge clk or posedge reset)
     if (reset)
        state = zero;
        case (state)
          zero:
             state = one;
          one:
             if (in)
               state = zero;
               state = two;
          two:
             state = three;
          three:
             state = zero;
        endcase
weibode01 发表于 2010-11-9 11:14:59 | 显示全部楼层
状态机是很有用的一个东西
GMT+8, 2026-5-24 04:11 , Processed in 0.053290 second(s), 25 queries .
