查看: 1979|回复: 1
求FPGA的描述性语言
qq87622 发表于 2010-6-3 13:35:43 | 显示全部楼层 |阅读模式
下面是一些程序谁能告诉我关键的语句意思!!
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY fenpinqi IS
PORT ( clk : In STD_LOGIC;
       clk_scan : OUT STD_LOGIC);
      END fenpinqi;
ARCHITECTURE rtl OF fenpinqi IS
SIGNAL cnt:INTEGER RANGE 0 TO 40000;
BEGIN
PROCESS(clk)
BEGIN
IF clk'event and clk='1' THEN
  IF cnt=cnt'high THEN
     cnt<=0;
   ELSE
  cnt<=cnt+1;
  END IF;
END IF;
END PROCESS;
PROCESS(cnt,clk)
BEGIN
   IF cnt>= cnt'high/2 THEN
clk_scan<='1';
ELSE
   clk_scan<='0';
END IF;
END IF;
END PROCESS;
END rtl;
Sunlife 发表于 2015-5-20 10:22:36 | 显示全部楼层
坐等。。。VHDL 没学过
GMT+8, 2026-5-23 07:00 , Processed in 0.032633 second(s), 20 queries .
