查看: 2588|回复: 0
按键问题
meng454619501 发表于 2010-6-8 16:56:58 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity key is
port(key,clk:in std_logic;
        LEDut std_logic_vector(7 downto 0)
end key;
architecture ky of key is
signal q:std_logic;
signal nn:integer range 0 to 7;
ky:process(key)
variable cnt1:integer range 0 to 2000;
variable cnt2:integer range 0 to 1000;
variable n:integer range 0 to 8;
variable mm:std_logic;
variable state:std_logic;
--variable ct:integer range 0 to 3;
state:=key;
if state='0' then
        if clk'event and clk='1' then
                if cnt1=2000 then
                        cnt1:=0;
                        state:=key;
                                if state='1' then
                                        if n=8 then
                                                n:=0;
                                                n:=n+1;
                                        end if;
                                end if;
                elsif cnt2=1000 then
                        cnt2:=0;
                        cnt1:=cnt1+1;
                        cnt2:=cnt2+1;
                end if;
        end if;
end if;
nn<=n;
end process ky;
keys:process(nn)
variable LED1: std_logic_vector(7 downto 0);
        case nn is
                when 1=>LED1:="11111110";
                when 2=>LED1:="11111101";
                when 3=>LED1:="11111011";
                when 4=>LED1:="11110111";
                when 5=>LED1:="11101111";
                when 6=>LED1:="11011111";
                when 7=>LED1:="10111111";
                when others=>LED1:="01111111";
        end case;
LED<=LED1;
end process keys;
end ky;
按一次键盘,检测到按键起来的时候开启计数器延时,然后流水灯移动一位,可是我按键却没有作用,我不知道问题出在哪里了,望高手指教
GMT+8, 2026-6-5 00:31 , Processed in 0.044145 second(s), 19 queries .
