查看: 1730|回复: 2
状态机—程序下到DE2-70上却始终维持复位状态,求指导!谢谢!
463764339 发表于 2012-7-9 15:26:40 | 显示全部楼层 |阅读模式
module train (reset, clock, sensor1, sensor2, sensor3, sensor4, sensor5, switch1, switch2, switch3, dirA, dirB);
        input reset, clock, sensor1, sensor2, sensor3, sensor4, sensor5;
        output switch1, switch2, switch3;
        output [1:0] dirA, dirB;
        reg switch1, switch2;
        reg [1:0] dirA, dirB;
        reg [2:0] state;
        parameter ABout = 0, Ain = 1, Bin = 2, Astop = 3, Bstop = 4;
        always @(posedge clock or posedge reset)
                        if (reset)
                                state = ABout;
                        case (state)
                                ABout:
                                        case (sensor12)
                                                2'b 00: state = ABout;
                                                2'b 01: state = Bin;
                                                2'b 10: state = Ain;
                                                2'b 11: state = Ain;
                                                default: state = ABout;
                                        endcase
                                Ain:
                                        case (sensor24)
                                                2'b 00: state = Ain;
                                                2'b 01: state = ABout;
                                                2'b 10: state = Bstop;
                                                2'b 11: state = ABout;
                                        endcase
                                Bin:
                                        case (sensor13)
                                                2'b 00: state = Bin;
                                                2'b 10: state = Astop;
                                        endcase
                                Astop:
                                        if (sensor3)
                                                state = Ain;
                                                state = Astop;
                                Bstop:
                                        if (sensor4)
                                                state = Bin;
                                                state = Bstop;
                        endcase
        wire [1:0] sensor12 = {sensor1, sensor2};
        wire [1:0] sensor13 = {sensor1, sensor3};
        wire [1:0] sensor24 = {sensor2, sensor4};
        wire switch3 = 0;
        always @(state)
                        case (state)
                                ABout:
                                                switch1 = 0;
                                                switch2 = 0;
                                                dirA = 2'b 01;
                                                dirB = 2'b 01;
                                Ain:
                                                switch1 = 0;
                                                switch2 = 0;
                                                dirA = 2'b 01;
                                                dirB = 2'b 01;
                                Bin:
                                                switch1 = 1;
                                                switch2 = 1;
                                                dirA = 2'b 01;
                                                dirB = 2'b 01;
                                Astop:
                                                switch1 = 1;
                                                switch2 = 1;
                                                dirA = 2'b 00;
                                                dirB = 2'b 01;
                                Bstop:
                                                switch1 = 0;
                                                switch2 = 0;
                                                dirA = 2'b 01;
                                                dirB = 2'b 00;
                                default:
                                                switch1 = 0;
                                                switch2 = 0;
                                                dirA = 2'b 00;
                                                dirB = 2'b 00;
                        endcase
 楼主| 463764339 发表于 2012-7-10 21:25:55 | 显示全部楼层
复位信号改为下降沿触发,在下面if条件语句中改为复位信号低电平有效。如果不可以需要添加按键防抖模块进行按键防抖
zombes 发表于 2012-7-15 17:11:28 | 显示全部楼层
仿真试下,复位一直是什么信号啊?按键复位?那么复位时低电平有效
GMT+8, 2026-5-23 18:08 , Processed in 0.033797 second(s), 22 queries .
