查看: 1244|回复: 0
vhdl
南盗 发表于 2012-8-31 14:33:19 | 显示全部楼层 |阅读模式
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY USB_FPGA IS
        GENERIC (
                FIFOLENTH        : integer := 1024;         --FIFO长度2048
                FIFOWITH        : integer := 16;        --FIFO宽度------------8----16---
                PACKAGENUM        : integer := 256        --FIFO单个数据包长度--512--256--
        PORT
                IFCLK                : IN STD_LOGIC ;
                RESETFPGA         : IN STD_LOGIC ;
--                FX2 SLAVE FIFO
                FX2FD                : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0) ;
                CTL0_FLAGA        : IN STD_LOGIC ;
                CTL1_FLAGB        : IN STD_LOGIC ;
                CTL2_FLAGC        : IN STD_LOGIC ;
                RDY0_SLRD        : OUT STD_LOGIC ;
                RDY1_SLWR        : OUT STD_LOGIC ;
                PA7_FLAGD        : IN STD_LOGIC ;
                PA6_PKTEND        : OUT STD_LOGIC ;
                PA5_FIFOADR1        : OUT STD_LOGIC ;
                PA4_FIFOADR0        : OUT STD_LOGIC ;
                PA2_SLOE        : OUT STD_LOGIC ;
                PA0_INT0        : IN STD_LOGIC ;
                PA1_INT1         : IN STD_LOGIC ;
                LED1                : OUT STD_LOGIC
END USB_FPGA;
ARCHITECTURE ARC_USB_FPGA OF USB_FPGA IS
--FIFO
TYPE fifo_arry IS ARRAY(0 to (FIFOLENTH-1)) OF bit_vector((FIFOWITH-1) DOWNTO 0);
SIGNAL fifomemory:fifo_arry;
SIGNAL fifowraddr,fifordaddr        : NATURAL RANGE 0 TO (FIFOLENTH-1) ;
SIGNAL data2usb,data2fpga        : STD_LOGIC_VECTOR((FIFOWITH-1) DOWNTO 0) ;
SIGNAL wrstate                : NATURAL RANGE 0 TO PACKAGENUM ;
SIGNAL fifoadrcs        : STD_LOGIC_VECTOR(1 DOWNTO 0) ;
SIGNAL slrdbuf,slwrbuf,sloebuf        : STD_LOGIC ;
SIGNAL led1buf                 : STD_LOGIC ;
BEGIN
LED1 <= led1buf;
PA5_FIFOADR1 <= PA1_INT1;
PA4_FIFOADR0 <= PA0_INT0;
fifoadrcs <= PA1_INT1 & PA0_INT0;
PA2_SLOE <= sloebuf;
RDY0_SLRD <= slrdbuf ;
RDY1_SLWR <= slwrbuf ;
PA6_PKTEND <= '1';
PROCESS(PA1_INT1)
BEGIN
IF(RESETFPGA = '0') THEN
        data2fpga <= FX2FD;
        FX2FD <="ZZZZZZZZZZZZZZZZ" ;
ELSIF(PA1_INT1='0') THEN
        data2fpga <= FX2FD;
ELSE
        data2fpga <= "ZZZZZZZZZZZZZZZZ" ;
        FX2FD <=data2usb ;
END IF;
END PROCESS;
PROCESS(RESETFPGA,IFCLK)
BEGIN
        led1buf <= '1';
        sloebuf <= '1';
        slrdbuf <= '1';
        slwrbuf <= '1';
        fifowraddr <= 0;
        fifordaddr <= 0;
ELSIF(IFCLK'event AND IFCLK='1') THEN
                led1buf <= '0';
                sloebuf <= '0';
                slwrbuf <= '1';
                IF(CTL0_FLAGA = '1') THEN        --wr to fpga
                        CASE wrstate IS
                                WHEN 0 =>
                                        wrstate <= wrstate + 1;
                                        slrdbuf <= '0';
                                WHEN PACKAGENUM =>
                                        wrstate <= 0 ;
                                        slrdbuf <= '1';
                                        fifomemory(fifowraddr) <= to_bitvector(data2fpga);
                                        IF (fifowraddr>=fifowraddr'high) THEN
                                                fifowraddr<=0;
                                        ELSE
                                                fifowraddr<=fifowraddr+1;
                                        END IF;
                                WHEN OTHERS =>
                                        slrdbuf <= '0';
                                                fifowraddr<=0;
                                        ELSE
                                        END IF;
                        END CASE;
                        IF((fifowraddr=511) AND (data2fpga="1111111111111110")) THEN
                                led1buf <= '0';
                        ELSIF(fifowraddr=(FIFOLENTH-1)) THEN
                                led1buf <= '1';
                        END IF;
                ELSE
                        slrdbuf <= '1';
                END IF;
        ELSE
                led1buf <= '1';
                sloebuf <= '1';
                slrdbuf <= '1';
                IF((CTL2_FLAGC = '1') AND (fifowraddr /= fifordaddr)) THEN --rd from fpga
                        slwrbuf <= '0';
                        data2usb <= to_stdlogicvector(fifomemory(fifordaddr));
                        IF(fifordaddr>=fifordaddr'high) THEN
                                fifordaddr<=0;
                        ELSE
                                fifordaddr<=fifordaddr+1;
                        END IF;
                        IF(fifordaddr=511) THEN
                                led1buf <= '0';
                        ELSIF(fifordaddr=(FIFOLENTH-1)) THEN
                                led1buf <= '1';
                        END IF;
                ELSE
                        slwrbuf <= '1';
                        data2usb <= "ZZZZZZZZZZZZZZZZ";
                END IF;
        END IF;
END IF;
END PROCESS;
END ARC_USB_FPGA;
希望有大神帮我写一个verilog的程序,就是上面的vhdl转换成verilog,要求是有点过分,但是确实是自己没什么办法。恳请帮我一下,谢谢了。。。。。
GMT+8, 2026-5-23 18:05 , Processed in 0.037994 second(s), 24 queries .
