查看: 4264|回复: 0
sram的verilog程序
CPLD 发表于 2010-6-23 14:25:07 | 显示全部楼层 |阅读模式
timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:
// Design Name:
// Module Name:    sram_test
// Project Name:
// Target Device:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module sram_test( rst        ,
                  clkin      ,
                  sram_ab    ,
                  sram_db    ,
                  sram_wr    ,
                  sram_rd    ,
                  sram_cs    ,
                  sram_be    ,
               error,
                  task_start , //Start    Testing ---LED1
                  task_finish,  //Testing  Finish  ---LED2
      flash_ce,
      flash_oe,
      flash_we
input           rst       ;
input           clkin     ;
output [17:0]   sram_ab   ;
output [1:0]    sram_be   ;
inout  [15:0]   sram_db   ;
output          sram_wr   ;
output          sram_rd   ;
output          sram_cs   ;
output error;
output          task_start ;
output          task_finish;
output    flash_ce,flash_oe,flash_we;
//ports
wire            rst       ;
wire            clkin     ;
reg    [17:0]   sram_ab   ;
wire   [15:0]   sram_db   ;
reg             sram_wr   ;
reg             sram_rd   ;
reg             task_start ;
reg             task_finish;
wire flash_ce=1;
wire flash_oe=1;
wire flash_we=1;
reg             clk_2;
wire            clk;
reg  [2:0]      STATE,NEXT;
reg             error     ;
reg  [15:0]     sram_db_reg;
reg  [15:0]     count      ;
//parameters
parameter     IDLE     = 3'D0,
               WRITE_1  = 3'D1,
               WRITE_2  = 3'D2,
               READ_1   = 3'D3,
               READ_2   = 3'D4;
assign  sram_cs = 1'b0;
assign  sram_be = 2'd0;
assign  sram_db = sram_rd ? sram_db_reg:'hz;
reg [1:0] clk_count;
always @(posedge clkin or negedge rst)
if(!rst)
   clk_count<=2'd0;
      clk_count<=clk_count+1'b1;
assign clk = clk_count[1];
//state machine
always @ (STATE or sram_ab or error or task_start)
     case(STATE)
     IDLE    : if(task_start)
                   NEXT = WRITE_1;
                   NEXT = IDLE   ;
     WRITE_1 : NEXT = WRITE_2;
     WRITE_2 : if( sram_ab >= 18'h3ffff)
                   NEXT = READ_1;
                   NEXT = WRITE_1;
     READ_1  : NEXT = READ_2;
     READ_2  : if(  sram_ab >= 18'h3ffff)//error ||
                   NEXT = IDLE;
                   NEXT = READ_1;
     default : NEXT = IDLE ;
     endcase
//registe the state
always @ (posedge clk or negedge rst)
if(!rst)
    STATE <= IDLE;
    STATE <= NEXT;
if(!rst)
        sram_ab      <=18'h3ffff;
        sram_db_reg  <=16'h1fff;
        sram_wr      <=1'b1;
        sram_rd      <=1'b1;
    case(STATE)
    IDLE    : begin
                  sram_rd     <= 1;
                  sram_wr     <= 1;
    WRITE_1 : begin
                  sram_ab     <= sram_ab+1;
                  sram_db_reg <= sram_db_reg+1;
                  sram_wr     <= 1'b0;
                  sram_rd     <= 1'b1;
    WRITE_2 : begin
                  sram_wr  <= 1'b1;
                  sram_rd  <= 1'b1;
    READ_1  : begin
                  sram_wr <= 1'b1;
                  sram_rd <= 1'b0;
                  sram_db_reg <= 'h1fff;
    endcase
if(!rst)
       error      <= 1'b0;
       task_start <= 1'b1;
       task_finish<= 1'b0;
       count      <= 16'h1fff;
   case(STATE)
   WRITE_1 : //if( sram_ab < 'd1024 )
                    task_start <= 1'b1;
                    count      <= 16'h1fff;
   READ_1  : begin
                 count<=count+1;
   READ_2  : begin
                 if( sram_db != count)
                     error <= 1'b1;
                       error <= 1'b0;
                       if(sram_ab >= 18'h3ffff)
                             task_finish <= 1'b1;
                             //task_start  <= 1'b1;
   endcase
GMT+8, 2026-5-24 07:50 , Processed in 0.030682 second(s), 21 queries .
