查看: 2728|回复: 2
用VHDL代码产生标准m序列的问题
CPLD 发表于 2010-6-23 18:39:49 | 显示全部楼层 |阅读模式
请教高手,小弟刚学写FPGA代码,最近要做一个低速率的误码仪,要求能与老外的误码仪互换(RAD 公司的LBT误码仪),LBT误码仪说明书上说能与满足ITU V.52标准(该标准已经被ITU O.150替代)的设备兼容,我需要在FPGA里面产生和LBT误码仪相同的m序列,长度是511.
------------------------------------这个是ITU标准上说的-----------------------------------
4.1 511-bit pseudo-random test pattern
This pattern is primarily intended for error measurements on data circuits at bit rates up to 14 400 bit/s (see
Recommendation O.153).
The pattern may be generated in a nine-stage shift register whose 5th and 9th stage outputs are added in a
modulo-two addition stage, and the result is fed back to the input of the first stage. The pattern begins with the first ONE
of 9 consecutive ONEs.
Number of shift register            stages 9
Length of pseudo-random sequence    2*9-1= 511 bits (2的9次方减1)
Longest sequence of ZEROs           8 (non-inverted signal)
按照上面的标准,我理解的该m序列的本原多项式X*9+X*5+1(X的9次方+X的5次方+1),
---------------------------------我用VHDL写的代码的一个片段---------------------------------------
signal m_code_out : std_logic;
signal fdbk       : std_logic;
signal shift_out  : std_logic_vector(8 downto 0);
process(clk)
    if rising_edge(clk) then
       if (reset = '0') then
          shift_out <= (others => '1');------初始状态全1
          fdbk <= shift_out(8) xor shift_out(4);
          m_code_out <= shift_out(8);-----最高位移位输出-----(这是我想要的n=9,长度为511的m序列)
          shift_out(8 downto 1) <= shift_out(7 downto 0);
          fdbk <= shift_out(8) xor shift_out(4);-----第5位和第9位模2加
          shift_out(0) <= fdbk;-----第5位和第9位模2加的值作为新的输入
       end if;
    end if;
end process;
 楼主| CPLD 发表于 2010-6-23 18:40:04 | 显示全部楼层
这个问题我已经搞定了,
把 fdbk <= shift_out(8) xor shift_out(4);这句放在process外面就可以呢
Sunlife 发表于 2015-5-13 14:05:03 | 显示全部楼层
GMT+8, 2026-5-23 11:35 , Processed in 0.055045 second(s), 24 queries .
