查看: 2946|回复: 3
VHDL 这是什么原因?
CPLD 发表于 2010-6-23 18:41:15 | 显示全部楼层 |阅读模式
我刚开始学,照书上写了一个程序,如下,
LIBRARY IEEE;
   USE IEEE.STD_LOGIC_1164.ALL;
   USE IEEE.STD_LOGIC_UNSIGNED.ALL;
   ENTITY CNT10 IS
     PORT(CLK,RST,EN : IN STD_LOGIC;
                    CQ: OUT STD_LOGIC_VECTOR(3 DOWNTO 0 );
                 COUT: OUT STD_LOGIC);
   END ENTITY;
   ARCHITECTURE behav OF CNT10 IS
   BEGIN
     PROCESS(CLK,RST,EN)
       VARIABLE CQI :STD_LOGIC_VECTOR(3 DOWNTO 0);
     BEGIN
          IF RST='1' THEN CQI :=(OTHERS=>'0');
           ELSIF CLK'EVENT AND CLK='1' THEN
            IF EN='1' THEN
               IF CQI<9 THEN CQI<=CQI+1;
                  ELSE CQI:=(OTHERS=>'0');
                END IF;
            END IF;
          END IF;
           IF CQI=9 THEN  COUT<='1';
              ELSE COUT<='0';
           END IF;
            CQ<=CQI;
   END PROCESS;
  END behav;
在编译的时候出现了这样的错误:
Warning: FLEXlm software error: Invalid (inconsistent) license key  The license-key and data for the feature do not match.  This usually happens when a license file has been altered Feature:       quartus License path:  D:\Program Files\altera\71\quartus\bin\directory\license.dat FLEXlm error:  -8,523 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".
Error: Current license file does not support the EP1C3T144C8 device
Error: Quartus II Fitter was unsuccessful. 1 error, 1 warning
Error: Quartus II Full Compilation was unsuccessful. 1 error, 1 warning
这是什么原因????
 楼主| CPLD 发表于 2010-6-23 18:41:30 | 显示全部楼层
第二个if else不对,可以另写一个进程,进行判断处理,这种描述的EN,rst两个信号对第二组的IF else也不会起作用。。。
 楼主| CPLD 发表于 2010-6-23 18:41:47 | 显示全部楼层
警告你的 license不是Altera提供的正版 license,所以无法做全编译。
原因是你的Quartuss没有破解,或者破解得不完整。
解决的办法要看你的Quartuss  版本------你可以在百度上搜到解决办法。
Sunlife 发表于 2015-5-20 16:45:16 | 显示全部楼层
GMT+8, 2026-5-23 07:48 , Processed in 0.057614 second(s), 24 queries .
